Old 12-20-2012, 08:41 PM   #1
nirtza79
Default SK 540 and DX6i gain control
Hi,
How can I use the gain control from my Tx on my DX6i?
It show in the software only Gear and AUXs and I have the Gyro on my Tx.
Trex 450 Sport V2 TT FBL SK 540
DX6i
nirtza79 is offline        Reply With Quote
Old 12-21-2012, 10:54 AM   #2
georgi UK
=] you need to activate & assign the switch in the Tx menu,
georgi UK
georgi UK is offline        Reply With Quote
Old 12-21-2012, 01:48 PM   #3
nirtza79
I don't know how well you know the DX6i but I cannot assign switches, all I have is one channel and it is the "Gyro". That means that I cannot use the remote gains?
DX6i
Old 12-21-2012, 02:33 PM   #4
georgi UK
=] I have the early first 2.4 version, what is your live data showing for the 6th channel?
georgi UK
Old 12-22-2012, 08:28 AM   #5
nirtza79
Hi,
The live data shows that it is working with my Gyro switch but the blue line above the tab does not move when I toggle the switch, is that an issue or can I trust it?
DX6i
Old 12-22-2012, 12:12 PM   #6
georgi UK
=] the blue bar must move, check out the 8 min mark =
georgi UK
Old 12-22-2012, 12:31 PM   #7
nirtza79
Thanks georgi,
Very informative video but that what I did, I set the tail gain to be on "Gear" and the live data shows that it works (it changes when I toggle the switch) but the blue bar above the tabs does not move with it.
DX6i
Old 12-22-2012, 12:37 PM   #8
georgi UK
=] yes, but does the flight switch change the blue bar?
georgi UK
Old 12-22-2012, 12:42 PM   #9
nirtza79
No, it only changes the live data %.
DX6i
Old 12-22-2012, 01:37 PM   #10
ICNU
You must set the correct gain or channel end point values in your TX in order to trigger the blue bar to switch banks. This is no different than setting up a switch on your TX to switch a normal tail gyro between rate and head hold. For example, I used to have my cyclic banks switch with my gain channel, so I set one side of the switch to -60% and the other side to 60%
Assigning the channel is only the first part.......you must set the values on that switch to trigger the bank change on the Skookum side.
ICNU is offline        Reply With Quote
Old 12-22-2012, 01:48 PM   #11
nirtza79
I am not sure I understand your reply..
I have my "Gyro" switch 0: 65.5% (50% in live data) 1: 61.5% (40% in live data), Is that what you meant?
DX6i
