| Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
I was able to get the zyx-s controller to work with a ar8000 with satllite, bonund with my 11x.
then switched it over to satellite only with DSMX-1. Now, on the channel monitor screen, the Ele, Alie, Collective, works fine, the Rudder and the throttle works on the monitor screen on the transmitter but does not work watching the computer. ? what to do ?
YTD Nitro smoked = 14 Gal YTD Flights 0311 Gaui NX4 106 flights, Fury 55 026 flights Smokem' if you got em' To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
OK, I'm about done with this tarot controller,
1. it binds ok with R921x, R921, AR8000, with sats, everything works with a standard receiver, but once the receiver is gone, and I'm connected with only Satellites, I loose the Throttle and the rudder channel turns into AUX3. Tried 4 different satellites, and bound with 3 different receivers. If I don't have it figured out by wednesday december 26, it will be listed under the sale forums.
OK, After Cannibalizing all of my helis for their receivers and sats.
I was able to get one combo to work, I think that the most important lesson I learned here is, you MUST use a AR7000 receiver. ![]() Got it to work with my 8103 radio with the DM9 moduel, also works with the JR11x. --- glad that is over with, now that everything is working smoothly, where is my beater heli kit ? Fast 480,.
Tried to bind the satelite with male-to-male in the multiport and aileron port?
Hk250, Hk450Fbl, Trex500fbl, Logo 600fbl, Logo 400Se, Walkeras, MaxiJoker3fbl-ap ship-helicommand Planes.. Futaba 14mz, spektrum dx8 |
yes, did not work 4 me, i saw alot of weird stuff,
I must have tried over 30 different ways to bind, with different sats and receivers, and without receivers,
#6 |
finally got my heli kit, built it last night, and got 11 flights on it today,
had problems with the satellite thing again, so I've got a full size receiver on there for now. What a pain, specs Alzec 480 kit, 325 tarot fb blades. custom wound 2221-2010 scop on 6s mks ds95 on cyc, ds95i tail. have a EX canomod canopy on it for now, till the kinks get worked out. inverted piro's, it wobbles, inverted climb out & piro, it's all over the place. (i think) during a full pitch rainbow, I was getting a very bad tail kick, almost 90 degrees. tried to crack the aliron, after about 6 seconds of crack, and little response, put heli into a hover, it started to crack all by itself, ? lol ? really, thats a delayed reaction. lol what settings do I need to adjust for this, I'm new to fbl, and only have little exp with v-bar. and the only exp I have with zyx-s if from today.
