Old 12-21-2012, 04:57 AM   #1
al30tsm
Default another ZYX-S question
Hi again,
sorry to pester you guys but i have another query regarding the Tarot gyro, on the servo trim page where you set the arms to 90 degrees using ch1 to 3, under a box named swash, what are the collective, aileron and elevator buttons for? are they for leveling the swash after doing the sub-trin?
Thanks, Alan
al30tsm is offline        Reply With Quote
Old 12-21-2012, 11:33 AM   #2
Dr. M
Correct. The zyx allows you to trim each servo individually, as well as offer the possibility to trim the swashplate by moving all servos together. I really like that feature.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 12-22-2012, 03:40 AM   #3
al30tsm
Thanks again Dr.M,
so does this feature allow me to level the swash at mid stick and at both ends of travel?
Aaln
Old 12-22-2012, 09:28 PM   #4
Dr. M
Not at the ends, only at mid stick. There's no way to level the swash at the ends, but you don't need to either, as the gyro will compensate for unequal travel.
Old 12-23-2012, 09:11 AM   #5
al30tsm
Dr.M, your the man, have a good one
Alan
Old 12-23-2012, 09:29 AM   #6
CopterGuy
Isn't it true that if the arms are at 90 degrees at mid-stick and the linkage geometries are correct, the swash will be level at high and low travel as well?
DX6i (with back light), Mini Titan E325 V1 converted FBL w/ SK-720, Mini Titan V1 converted FBL w/ ZYX-S, mCPx V2 converted BL with HK parts, Phoenix
CopterGuy is online now        Reply With Quote
Old 12-23-2012, 12:28 PM   #7
Dr. M
Theoretically yes. However we live in an imperfect world where small differences in the swash servos may result in unequal travel. In particular, servo POTs are the components that introduce the most error...
Old 12-23-2012, 04:29 PM   #8
CopterGuy
Very true. Great point. I have my first swash leveler tool on order. Always eye balled it to this point but know I need to dial in the helis better. Snow is on the ground so I have plenty of time to play around with the setups.
