| nano CP X Blade nano CP X Helicopters Information and Help |
Hi.
Got my nano cpx today, but i cant bind it. I plug in the battery in the heli, the blue led flashes quickly. Then i hold Trainer switch and turn on transmitter, after like 2sec i release trainer switch and do full rudder. Then after a few seconds the led flashes slow, and i can input aileron and elevator, but i cant input throttle, the pitch is just going on, not the throttle. What am i doing wrong? Every switch is at 0, all trims is at 0, i tryed to trim the throttle down with no success. |
Sometimes they have that issue. If its brand new, take it back.
lower your throttle end point, esc is not seeing 0%
Also try moving the Tx further away.
avoid frustration call Horizon hobby they will help you. I had the same issue it was a bad board.
Trex600N Pro..Trex600N..Trex500..Trex450SE V2.. JR Venture 30.. |
#6 |
Solved. Some channels has been reversed.
This is the most stable heli ive ever flown!! kds 450 fbl with Zyx-s hk 450pro v2 |
