Old 12-21-2012, 09:58 AM   #1
RCHSF
Default Tarot FBL Unit
My budget is very low this time of year. I'd like to get a FBL unite for this heli so I can fly it. It's been over a year since I've flown.
And I guess I'll need a Flight pack regulator, and a step down for the tail also. I have everything else. Except a pair of EC5 connectros. I can't seem to solder a deans on with my low watt iron. 35watt guess I'll need at least a 60 watt to.
I'm looking at this Tarot ZYX unit, does it just have the one Sat Port? And are they all the same?
And my other concern is my heli has the servo distance 20mm from output shaft on servo linkage rod. Per the Manual. It's perfectly straight up and down though. Any problem for the Tarot?
Jr Vibe 500E
Power 25 Heli
Eflite 60A Pro
Hitec 5245 Dig MG X3
Jr 3500 tal servo.
RC Bug Beater
RCHSF is offline        Reply With Quote
Old 12-21-2012, 12:42 PM   #2
Dr. M
The ZYX-S has the ability to use a single sat, or a full Rx (which may have its own sats).
Servo arms at 20mm for a 500 helo is a bit much, unless the JR has some sort of weird geometry. 16-18mm will be much better on most designs.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote
Old 12-21-2012, 01:14 PM   #3
RCHSF
All I know is the Manual for the Vibe 500E says 20mm from the screw that holds the servo arm on, to where the ball bolts on.
But the heli came as a FB heli, so that may be why it says 20mm.
RC Bug Beater
Old 12-21-2012, 01:55 PM   #4
AKPhill
Shouldn't be a problem zyx has to be told how far to move the swashplate if it flew good as a fb then the same settings should work with the fbl
Raptor 50 se v2, raptor titan 50
Hirobo Shuttle ZX, trex esp 600
trex esp 500 fb
trex esp 500 fbl
AKPhill is offline        Reply With Quote
Old 12-21-2012, 02:14 PM   #5
Dr. M
Actually, FB geometry is different than FBL, because of the two unequal levers on the washout arms and Bell-Hiller mixing arms. These, in effect, reduced the servo-pitch coupling ratio. In FBL systems, we have a direct swash-grip linkage, which can have too much mechanical gain for a gyro to effectively control.
You'll get the definitive answer during the ZYX setup, where you'll try to get 12 max collective by adjusting the Collective Range setting on the gyro using the PC software or field programming box. This number should be between 60 and 80. If it's lower than 60, your cyclic servo arms are too long, if higher than 80, servo arms are too short.
Goblin Speed | iKon
Old 12-21-2012, 02:36 PM   #6
RCHSF
Thanks AKPhill & Dr.M I guess I'll just buy the unit and see if I can get it to work. Guess I'll try and get the USB programmer, instead of the feild one, save a few bucks maybe. I have not flown this heli yet, or any heli in over a year. I bought this vibe off a great guy on the other forum, a few months ago. I always wanted a FBL heli. Best heli I ever had. I got it for $250 shipped. With new parts still in pack. With good servos all around. Before I got it, I traded for a new Clone of the Vibe 500E, and it's Fly Bared, and I bought servos for it. Analog MG Hitecs for cyclic, and Jr DS3500 for tail. And put a quark clone gyro on it. New motor same as the original vibe, but dropped in a 12t pinion. I'm trying to build the head & tail up with a few name brand parts and fly this one first to get back in the swing before trying the FBL one. So I got a long ways to go before I'll get anything in the air, probably spring time.
RC Bug Beater
