Old 12-21-2012, 12:40 PM   #1
Wesley888
Default More hovering time using 3s or 6s?
Have anyone done any testing on the effect of changing the motor for pure hovering time? For AP work, longer flight time is always better. I'm curious if changing the stock 3s motor on a 450 to 4s (or even 6s) would make much difference.
Align 450 with NAZA-H, 450XL, XCell60, Align 700e, Skookum SK 720, SK-GPS, DX8. ArduPilot (APM 2). Talon 625 Hexa with NAZA-M.
Wesley888 is online now        Reply With Quote
Old 12-21-2012, 01:52 PM   #2
R_Lefebvre
Conceptually, for a given wattage, it's more efficient to do it with more Volts and less Amps. Now, real world, can you measure the difference? I dunno.
You'd probably get more bang/buck with Asymmetric blades. I actually just ordered 3 sets from Spinblades. 325, 600 and 700's, plus tails.
I'll be testing out the 325's on my 450 shortly. Main issue I've heard is the "ballooning" problem, but I don't think that will be a problem for me anymore. We'll see.
-Rob
Ardupilot/Arducopter Developer
R_Lefebvre is online now        Reply With Quote
Old 12-21-2012, 02:01 PM   #3
Wesley888
I have the Spinblades. It is much heavier and make the heli behave a little different. I haven't time the hover time yet. Since the Spinblades for 450 is not that much different from the 3D one, as you can see the estimated time gain from their official website, I don't expect too much from it.
I only have 450s and a 700e. I'm still afraid to put any fancy electronic on the 700 yet, nor test anything on the 700 at all, since the crash cost is a bit too much for my wallet.
Old 12-21-2012, 08:28 PM   #4
Chucky777
Default flight time
For longer flight time you need to increase the amps in you battery. By either running two of the same amp batteries in parallel or increasing the size of you battery. If you increase the cell count you only increase the power to weight ratio.
Chucky777 is offline        Reply With Quote
Old 12-22-2012, 01:08 AM   #5
Wesley888
Let me rephrase, for the same amount of power (V x A), also roughly same amount of weight, would a 6s set up better or worst then 3s setup?
For example, 1 pack of 6s 1800mAh battery with a 6s motor versus 2 packs of 3s 1800mAh battery (or 1 pack of 3s 3600mAh battery) with a 3s motor.
Old 12-22-2012, 06:49 AM   #6
FPVflyer
I do easily 20mins hovering with my rex 600 pro, spinblades, 12s 5300mah and 330kv scorpion motor..
FPVflyer is offline        Reply With Quote
