Old 12-21-2012, 02:11 PM   #1
Scotty T
Default Ice 50 Lite Settings?
Anyone ever post the Castle setting that they successfully used with the ICE Lite 50 with the stock motor?
Does anyone know the stock motors specs like in particular the poles?
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is online now        Reply With Quote
Old 12-21-2012, 02:33 PM   #2
GSPI
It's a six pole motor Scott. I'm running stock right now so that's about all I got.
Beating the air into submission... one Blade® at a time!
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote
Old 12-21-2012, 02:51 PM   #3
65L88
Six pole, 4500kv, should be all you need to set the ice lite up. I think I have pwm set at 8khz on my ice lite and my Wicked motor, should work ok for the stock motor as well. I don't think it's recommended to use outrunner mode for pwm setting on helis.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3
65L88 is offline        Reply With Quote
Old 12-22-2012, 03:21 PM   #4
xpantz
Here is mine.
Not stock but just change the KV and GOV speeds. Your BEC voltage should be 5 for stock too.
ID:	376111   Click image for larger version
ID:	376112   Click image for larger version
ID:	376113   Click image for larger version
ID:	376114   Click image for larger version
xpantz is offline        Reply With Quote
Old 12-23-2012, 05:46 AM   #5
Scotty T
Xpantz, now that's what I'm taking about!
Thank you!
Addicted to Helis
