Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 12-21-2012, 03:05 PM   #1
Incarus
Default c05 work?
Thinking about getting a nano...don't know anything about it..
Will a c05 from an mcpx project fit /work....does brushless main motors require better tail or extended tail or both..
I don't wanna go crazy on this like I dud with my 4 MCPXs. Lol
Thx
Vinny
Incarus is offline        Reply With Quote
Old 12-23-2012, 07:22 AM   #2
Incarus
No body can tell me if it would fit?
Old 12-23-2012, 08:46 AM   #3
NCcraig
If it did fit, I don't know how you would mount it.
Team Newb pilot
BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513.
PM me about mCPX & NanoCPX BL conversions.
NCcraig is online now        Reply With Quote
Old 12-23-2012, 09:57 AM   #4
Incarus
I dont have a nano to check out so i was just wondering it it was a posibility....
I have a c05.....wanted to see if it was an option if i get a nano down the road
Old 12-23-2012, 10:43 AM   #5
NCcraig
There is no bottom plate on a Nano so you wouldn't have any way to secure the motor unless you made something.
Team Newb pilot
Old 12-23-2012, 12:16 PM   #6
Incarus
Hmmm....thanks for the info
How does the inrunner stay locked into the barrel seems like it slides in...I'm sure I'm missing something since I don't have one to paw at........
As far as a c05..... if one can be installed succesfully....is it worth it?
Too much weight....not powerful enough compared to the motors that would fit with In without hassle?....have to use an xp7 I'm sure...but wanted to put it out there to see what yi u guys think
Old 12-24-2012, 10:06 AM   #7
pjacq
Default not worth it
I would say it is not worthe the extra work before they came out with the drop in fit motor I had used this to install my motors...I put one on an co5 and it did fit but the shaft I have replaced with the 1.5mm to fit in my mcpx so now it is to short for the nano....
ID:	376631   Click image for larger version
pjacq is offline        Reply With Quote
Old 12-24-2012, 12:40 PM   #8
alcangie
Default maybe
i was playing with this same idea a while ago, since I had a brushless mcpx with this exact motor, but I didn't find a good way to mount the motor. Maybe this could be done if you modified the bottom plate somehow, maybe with a piece od carbon fiber plate and then some screws, but I think also the motor shaft is not long enough to reach the main gear. Anyway, in the end i decided to just buy a new direct fit motor and a new esc, and i have just put it together today and it rocks, it's much better than stock with the 135000 Kv and a 8 tooth pinion.
br
alen
MSH Prôtos 500: FBL, savox, beastX
Blade 400 3D,Hitec HS65mg, Spartan Quark, Hitec 5084MG, Align 35A X esc
Blade Mcpx-brushless, SR-120 tail
Blade nano cpx, brushless nanoheli kit
alcangie is offline        Reply With Quote
Old 12-24-2012, 05:10 PM   #9
Incarus
i came accross this post...and was kind of thinking the same lines...
then the question is the weight penalty of motor/esc etc worth it..
for me...i can save 20 some odd dollars since I have the motor laying around...thoughts?
post #50 on link below
http://helifreak.com/showthread.php?t=459685&page=5
ID:	377088   Click image for larger version
Old 12-30-2012, 06:15 PM   #10
Spinny
Chek out the pdf on this post. You can mount a c05 easily.
http://helifreak.com/showpost.php?p=...7&postcount=22
Spinny is offline        Reply With Quote
