Old 12-21-2012, 08:37 PM   #1
byter182
Default DS510 Servos Vibrating During Full Throttle
Hey Helifreaks,
I'm the original owner of a Trex 500 ESP upgraded to an i2 FBL head w/a BeastX FBL controller. Heli's never been in a crash. Recently, I changed the main gear to the slant main gear w/a helical pinion. For some reason, on high throttle my DS510 cyclic servos visibly oscillate which is very noticeable during a hover as you can see the whole heli wobbling at the skids. Main blades are tracking perfectly. Prior to changing the main gear, I had the same issue w/one of the servos which I subsequently changed to a new one. Problem went away. However, now I'm getting that same oscillation on all three cyclic servos.
Anyone have a similar problem that may be able to shed some light as to how to resolve this?
Thanks in advance,
Byter182
Trex 500 w/BeastX & i2 Head, Trex 550e w/BeastX & DFC
600EFL Pro w/SK720 & TracX Head
Logo 600se w/Blue MiniVBar, PowerJive120, Pyro 700-45L
Red SAB WobblinGoblin770 w/the iKon
byter182 is offline        Reply With Quote
Old 12-22-2012, 09:54 AM   #2
Ghostrydyr
could be a million things, what servo are you using for the tail, if its a reoccurring prob with your cyclics, could be the tail servo is causing it,
Ghostrydyr is offline        Reply With Quote
Old 12-22-2012, 10:16 PM   #3
byter182
Using an Align DS650 tail servo. So where do I start looking?
Old 12-23-2012, 08:51 AM   #4
bstanley72
As said above it could be many different things. However, are you sure the wobble is related to the servos? It sounds like to me you have a vibe somewhere. I had a similar problem on my 500. The bird would oscillate and it was most noticeable in the skids. Turned out it was a shot motor bearing.
Compass Atom 500, DJI 450 Flame Wheel, mCPX Brushless, Nano CPX, T-28 Trojan, "Crash Proof" Hawk Sky, DX8, overinflated sense of self worth!
bstanley72 is offline        Reply With Quote
Old 12-23-2012, 08:00 PM   #5
blax1
Probably vibration related the BeastX is giving involuntary inputs to servos
Take mains and TR's off spool up, watch for involuntary swash deflections through the full collective range it should be nice and even up and down, dont move the cyclic stick when doing this.
Kyosho Caliber 5 OS50 Hyper, GY401, S9254, 4x JRDS8231's,B6T Glow/Reg 1900Mah
Avant Aurora
OS91SX-H Ring C-Spec, RJX Pipe, Spektrum AR7100R, 2x SPM9545 Sat-Ant,
SPM9540 Onboard Data logger, Outrage XPRX 7.4 2S2P 5000Mah Rx pack, 4xJRDS8717's, Spartan DS760, Futaba BLS251 TR Servo,
Curtis Youngblood RadiX 710's, 105 TR's, 105 Super Stubz.
blax1 is offline        Reply With Quote
Old 12-23-2012, 11:56 PM   #6
byter182
Good idea. Will give it a try and tune back in.
Old 12-25-2012, 03:15 PM   #7
701superjet
Ya I would say it's probably vibration and the best x. Also could be getting interface from the high voltage side. Like having esc/batt wires ran to close to other electronics.
-trex700n
-trex600n
-trex500
-trex450
-trex250 ...blade mcx...best cat toy so far.
...& Aurora9
701superjet is offline        Reply With Quote
