Old 12-21-2012, 10:34 PM   #1
Bananaslug
Default New to FBL, needing some guidance!
Ok, this is my first fbl heli. 6hv with Skookum 540 and YGE 90hv. I want to use the governor on the Skookum. Do I need a RPM sensor? The YGE has two leads coming off of it. One says ProgCard and the other says Reciever. I was under the impression that I didn't need a RPM sensor. I am so lost lol.
6HV
Bananaslug is offline        Reply With Quote
Old 12-22-2012, 12:35 AM   #2
Jeff_Barrett
Nope. The newer YGE 90 and up all have built in phase sensors ... take a peek at the manuals (sheets of paper) that came with the ESC. It tells you exactly which is your sensor port, and you want it plugged into IO-C
Here's a video from Skookum on setting up your governor:
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 12-22-2012, 01:07 AM   #3
Bananaslug
Thanks Jeff! I forgot all about the videos. I'm in a bit of a fog after spending the last few hours at the bench. I bought the unit used and didn't get any manual with it, and with Helifreak acting up I was pretty much on my own. I'll go check out the videos... thanks again.
6HV
Old 12-23-2012, 07:32 PM   #4
Jeff_Barrett
Yeah, they don't ship with the manual (usually they are stored on the memory card for the SK720) ... you typically get a slip of paper with the URL on it for the manual.
Let us know how it goes!
