| Warp 360 Compass Warp 360 Model Helicopter Discussion |
There is no way to remove the main gear from its location, not enough room in the frames. Tried pulling the motor back etc, there is a slight cut out but not enough on my frames. At about 2mm short.
Will have shave it with a dremel drill, no biggy. Anyone else have this issue? BTW she is one tough bird. head into the ground with main blades and canopy mounts broken that's it! The way the skids are designed is very clever, you'll never need to replace em on impact. They just move out of their slots.
6HV + VBAR FULL 5.3 PRO To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Compass 7HV ULTIMATE VBAR 5.3 PRO Gens 5300 / Revo 4400 60C WARP 360 / Turnigy LIPOS Balances GREAT! |
I dremeled enough out of one side of the frame for the maingear to slip out..
130X stock | T-Rex 450PRO v2, AR7200BX | T-Rex 500PRO DFC, HC3-SX | Warp 360, HC3-SX | AMA member |
#3 | |
Cheers
No issue here on mine, but it is a tight fit ... I have to slip the belt off and move the main gear slightly forward in the frame to get it out.
Owner - RCHeliCanada.com Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Mine comes right out no problem but I remove the owb sleeve first then it's easy.
Steve |
#6 |
Lighty , you tale out Jesús Bolt ? No issues there , main and tail gears go out perfectly . No dremeled your frame
![]() Last edited by Bob O; 12-22-2012 at 09:09 AM.. Reason: reduce pic size |
#7 |
I took the jesus bolt out and slid the main shaft out, something else has to come out?
#8 |
Silly me!
One way sleeve just pops out. I didn't build my kit hence my issue.
#9 | |
Gravity Fighter |
#10 | |
It seems the warp was designed with very tight tolerances for the cutouts (had to dremel a bit to clear a belt guide as well), but with pretty low tolerances in the actual manufacturing. It wouldn't have been the end of the world to add 2mm extra for the pulley cutouts instead of leaving 1mm to spare on each side... I have a first batch kit though, it might have been fixed in subsequent batches.
