Old 12-22-2012, 07:20 AM   #1
NSpeziale
Default kontronik throttle percentage
I was told that using kontronik mode 4 with calibrated atv that your desired headspeed should be reached at %80 throttle curve for maximum power and efficiency. Is that correct?
NSpeziale is offline        Reply With Quote
Old 12-22-2012, 07:28 AM   #2
helicraze
Its ideal so it has enough headroom and not generate too much heat on esc
helicraze is offline        Reply With Quote
Old 12-22-2012, 12:11 PM   #3
Wh1teAfr1can
Read my post about how to calculate it and you can get an idea. But not adjusting the atv is the way to go
Richard Zappe
Team Manager Kontronik USA Team minicopter
Diabolo Kosmik 200, Pyro 750 - 50 Comp, Diabolo S #RZ, Diabolo 550 Jive Pro 120, Pyro 650-103 Comp
Wh1teAfr1can is offline        Reply With Quote
