Old 12-22-2012, 08:16 AM   #1
jamin_00
Default Kosmik heatsink with fan.
Just arrived.
It simply plugs in to one of the sensor ports.
Just need to know what side and wheres the best place to put it?
Sponsored by
Optipower
jamin_00 is online now        Reply With Quote
Old 12-22-2012, 11:10 AM   #2
jhheli
I would but it in the middle on top where the fet sits under, the whole top area serves as a heat sink for the fet, its a nice compact unit.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA
jhheli is offline        Reply With Quote
Old 12-22-2012, 11:10 AM   #3
malc1
Can you put a photo up Ben?
How are you planning on fixing this to the ESC?
---- Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N YS120 Vbar v5.3 ----- T Rex 600N YS60SR Vbar v5.3 ----- MA Spectra `G`----- T Rex 500 Gyrobot 700 ---------- Vario Sonic ----
malc1 is online now        Reply With Quote
Old 12-22-2012, 11:12 AM   #4
Wh1teAfr1can
The fan goes on the top side of the esc where all the labeling is and dead center
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is online now        Reply With Quote
Old 12-22-2012, 12:41 PM   #5
jamin_00
Cool.
Will prob use thermal tape so it wont ruin the finish on the Kosmik. I cant upload pics for some reason, keeps timing out???
Sponsored by
Optipower
Old 12-22-2012, 12:46 PM   #6
malc1
Was wondering about the thermal tape - are we sure that this won't leave any sort of marking on the Kosmiks surface?
I've just seen the timing out message as well????
Old 12-22-2012, 01:03 PM   #7
jamin_00
Even if it does it will be a lot less than using Artic Silver thermal adhesive or the like
Sponsored by
Optipower
Old 12-22-2012, 01:13 PM   #8
malc1
Yeah I suppose you're right about that.
Wouldn't mind knowing though from anyone who has used the tape before.
Old 12-22-2012, 03:21 PM   #9
Magneto
Thermal tape comes off clean atleast the 3M 8815 does. Heres a pic of the FETS Click image for larger version
Team
USA Team Minicopter
www.peakaircraft.com
Magneto is offline        Reply With Quote
Old 12-22-2012, 03:30 PM   #10
jamin_00
What thickness would you recommend?
Sponsored by
Optipower
Old 12-22-2012, 03:36 PM   #11
Magneto
8815 is very thin 15 mils. and works great .
Team
USA Team Minicopter
Old 12-22-2012, 03:42 PM   #12
malc1
Thanks Magneto, useful information here.
Old 12-22-2012, 03:48 PM   #13
jamin_00
Yes, thanks Magneto.
Malc, found a place here http://www.digikey.co.uk/product-search/en?FV=ffec1f96
Sponsored by
Optipower
Old 12-22-2012, 03:51 PM   #14
malc1
Thanks Ben.
Old 12-23-2012, 03:02 AM   #15
smsodhi
By using the heatsink on the helijive/jive you can increase its amp rating. Does the same apply to the Kosmik as well?
TRIABOLO P800 Kosmik HC3-SX 255/256
DIABOLO 4530 Kosmik HC3-SX 690/105 255/256
Futaba 12 FG
smsodhi is offline        Reply With Quote
Old 12-27-2012, 12:42 PM   #16
jamin_00
No, in a word. The Kosmik can go over 200a. It can peak much much higher but if it hits this max, even for a millisecond it will shut down. Having the heatsink/fan will aid in the cooling which will help to delay it shutting down if you are driving it hard
Sponsored by
Optipower
Old 12-27-2012, 03:26 PM   #17
rebeltrousers
So the Kosmik 160 has a ceiling 40a lower than the 200 in a spike??
Where approx is shutdown??
rebeltrousers is online now        Reply With Quote
Old 12-27-2012, 03:28 PM   #18
jamin_00
I do not know at what value the 160 will perform a hard shut down.
Sponsored by
Optipower
