Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 12-22-2012, 09:38 AM   #1
Twill
Default Nano cutting out in spool up
My nano won't even take of little and motor cut in and out. It will almost take off but then will just shut off. Tried new batteries, plug connection, changed motor to brushless, still is doing same thing. Anything I'm missing
Travis(twill)
Aircapitalheli.com
Xnova motors and kbdd blades
Twill is offline        Reply With Quote
Old 12-22-2012, 09:54 AM   #2
z_man_95
Make sure the gear isn't making the shaft too tight. Meaning that the bearings aren't squeezed between the gear and mainshaft collar.
Lynx 130X, Microheli 130x, Helimax MX450 FBL, Pantera 50 Nitro, Pantera 50 electric conversion w/ quattro head, Storm 250 w/ CC3D, DJI FW450 w/ Naza, FW650 w/ WKM, Phantom 3A, QuadH20 w/Pixhawk, CYE Stingray 500, and VDI ShadowHawk
z_man_95 is offline        Reply With Quote
Old 12-22-2012, 10:09 AM   #3
Twill
Did that
Travis(twill)
Aircapitalheli.com
Old 12-22-2012, 10:28 AM   #4
Nytflyer
Try a new tail motor. Could be going bad drawing to much current which shuts down the board.
- 130X
- 180 CFX / uBrain
- Blade 350QX3 and Nano Quad
- DX7S
Nytflyer is offline        Reply With Quote
Old 12-22-2012, 12:04 PM   #5
Twill
Ok I will try that. didn't think of that
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 12:34 PM   #6
Twill
Ok so still have the same problem cutting out I have already replace the tail motor, 3 in 1, went mild brushless kit, it's still doing it I don't understand. also pre warmed my batteries which are brand new and still is doing it any suggestions. I need help
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 01:40 PM   #7
Twill
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 02:26 PM   #8
NCcraig
You may have a main motor FET going bad.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
DX9, AMA# 966513.
NCcraig is online now        Reply With Quote
Old 12-29-2012, 02:26 PM   #9
Twill
Brand new 3 in 1
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 02:28 PM   #10
mixfisto
sometimes my elevator servo gets stuck causing this same issue. i just give the little servo gear a nudge and it re-centers itself...she flies fine after that.
good luck
mixfisto is offline        Reply With Quote
Old 12-29-2012, 02:48 PM   #11
NCcraig
Sounds like you have replaced everything except the servos and your TX. Process of elimination I would supose.
Team Newb pilot
DX9, AMA# 966513.
Old 12-29-2012, 03:00 PM   #12
Twill
Must be servos cause I even replace the tx
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 03:06 PM   #13
mixfisto
Craig, while your here, might as well ask a related?
The mild bl nano I got (bought used from a guy who you built for a few weeks ago) is getting about 3 mins of medium use (a few flips, etc) before having to land (coming down with about 3.65-3.7v on newish stock batts). Is this about right?
Old 12-29-2012, 03:10 PM   #14
Twill
What size batteries
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 03:11 PM   #15
Twill
I stock sorry missed that. That seems good for stock batteries
Travis(twill)
Aircapitalheli.com
Old 12-29-2012, 03:29 PM   #16
NCcraig
On stock batteries, that is about right. I got some Hyperion 160's in today and they seem to have a bit more punch to them.
Team Newb pilot
DX9, AMA# 966513.
Old 12-29-2012, 04:57 PM   #17
mixfisto
OK, thanks.
So would you recommend the Hyp 160's over stock?
Old 12-30-2012, 12:50 PM   #18
NCcraig
OK, thanks.
So far but I haven't had enough flights on them to be positive about them yet.
Sent from my DROID RAZR using Tapatalk 2
Team Newb pilot
DX9, AMA# 966513.
Old 12-30-2012, 04:00 PM   #19
xpcm
Where did u get them nc
xpcm is offline        Reply With Quote
