Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 12-22-2012, 02:00 PM   #1
soupy01833
Default can I?
So my brushed main motor spins constantly when plugged into the board. Can i use the small positive signal on the back of the board?
It seems like the negative point does not work. I am thinking it is cause the fet is bad?
Sound ok?
soupy01833 is offline        Reply With Quote
Old 12-22-2012, 02:41 PM   #2
vertico
No, you will need an esc to drive a brushless motor to use that spot.
You might as well get a brushless kit as it is nearly the same price as a new 3in1.
Or send it to megastumbler (megasmicros.com) and have him check out the board. He does amazing work.
130x - 300x - Goblin 500 - mCP X BL - mCP X HP08s Double Brushless
vertico is offline        Reply With Quote
Old 12-22-2012, 03:15 PM   #3
soupy01833
ok i was not specific. I have a brushless kit set to neg ppm. What i want to do is change it to postive and use the small point on the back. just making sur it is possible
Old 12-22-2012, 04:33 PM   #4
soupy01833
Nevermind. I used another 3 in 1 i had and it is working great. This board has a missing resistor on the front. A bad motor fet and I think the pad in the back is lifted. Bought it used so not sure how much was already there.
I will either buy a new board or get this one fixed if someone is up to the task
