| Realtime Video and FPV Discussions of receiving video in realtime from the aircraft |
so i got my goggles in and the EZosd and 5.8 Tx ive spent the better part of an hr or so looking for a video, i can follow the manual on hook up but im not gutting image threw the goggles, is there a sync or pair procedure or how does this work the manual only tells wireing setup and how to adjust the menu after you get image.. im about to head to the field and thought it would be nice to try these out but cant spend 6 hrs trying to figure it out.. will be dark by then can someone give me some info on this?
Don't Judge me, You don't know my life.. |
The FatShark Predator v2 setup manual..
http://www.fatshark.com/uploads/pdf/1719-1.pdf Did you remove the cam lens cap? Does the cam have power? Did you transmit without the antenna? You should see static in the goggles, if not maybe power and/or need to use another channel? |
I just get the grey screen. How so you power the camera and hook the OSD? Splice into it?
Beep, Beep, Honk, Honk, Over and Out Rotorhead
When I power up my goggles, all I see is white static (no grey screen) until I turn on the tx... But I did need to scroll thru the goggle channels (maybe ch 1 or 2 I am using).
http://fpvlab.com/forums/ Last edited by Skapr1; 12-29-2012 at 05:51 PM.. |
Still can't get the fatshark to work even bypassed the OSD and went cam>tx RX>goggles nothing. So I got to lookin. Is the BX pin on the RX supposed to be gone??
#6 |
I don't know. My Fat Shark Predator V2 Goggles has the rx inside!
#7 |
Yeah that is an internal chip. I had to order it. It works now it was a diffrent problem
#8 | |
what was the issue? might help others down the road...
No I didn't misspell Daneger, my name is Dane..get it? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "Flyin' high again..." -Ozzy Osbourne |
#9 |
Well I had the antennas on backwards RX on tx and tx on RX. Also mine I gotta turn on. Tx then goggles then RX
