| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
I think on the DX6i you would hold the roller down while powering up. You need to set the swash type to 1servo/90* is how it will read on the menu (I think).
Ok just looked at a manual from my older DX6i I used to have. Unless it change here is how you get to the List/Setup menu where you can change the swash type. "From any program function screen, pressing and holding the roller for more than three seconds then releasing the roller will return the display to the LIST or SETUP screen."
Compass 6HV - SK540 - MKS HBL665/669 Trex 500 ESP - SK540 - 510's/BLS251 DX8 / Phoenix / Persistence ~"See the heli, fly the heli"~ |
#22 |
Thank you larry227 I appreciate the help. I'll give it a try tomorrow.
#23 |
There's an easier way. Just click your wheel into ADJUST list, then scroll all the way down to the last choice which is SETUP list click on it. Scroll down to choice #5 Which is SWASH TYPE click on that. Choose ONESERVO90. and your done. Then just use travel adjust to make sure all the fields on step 23 are green and you should be good to go.
#24 |
Thank you I figured it out before. I thought that was another function.
#25 |
on step 15 on the second wizard is swash set up. when doing this step your blades are stright front to back. it asks to adjust your helicopters maximum clyclic pitch 10 degrees. when doing this do you use the front blade or rear blade. im using a digital pitch gauge if it matters.
this is step 15 With your rotor positioned as shown in Step 13, use the "Aileron Cyclic" mixing field on the Swash tab to adjust your helicopter's maximum cyclic pitch. Ten degrees is a good starting point for most sport fliers. Try to keep swash mixes to 60% or less. This prevents unwanted interaction at max and min collective. |
#26 | |
#27 |
the reason i was asking is because i got 10.0 on the rear and -07.5 on the front. sorry i'm a beginner.
#28 | |
Place your blades 90 degrees to the heli and check the pitch on each blades. They should both be at 0 degrees at mid stick. You can check this this without being connected up to the software (make sure you unplug two of the three motor wires so the motor can't start) If at mid stick all servos are 90 and you don't have equal pitch on each blade, you will need to adjust the links mechanically so that both blades read the same. It sounds like you might be going through the software setup without first having the head zeroed out mechanically first. |
#29 |
I did zero out the head mechaniclly. I could only get it to 0.03 and -0.03 when I did the zero
#30 | |
You can twist the blade with the gauge on it and see the values wander a couple degrees as the linkages move a bit. |
#31 |
Thanks your right about the digital gauge there really sensitive to movement. To get the most accurate reading you probably need to set the gauge in the same exact place. I didn't know how sensitive they are
#32 |
=] you need to calibrate the mast to the zero gauge to avoid double readings....
georgi UK |
#33 |
Sorry but how do you do that
#34 |
What Georgi means is your readings should be relative to the main shaft since the blades you are measuring are 90 to it and not the table, ground or whatever the heli happens to be sitting on that may or may not be level.
I take the head button off my helis and zero the pitch gauge on top of the head block, then measure the blade pitch. This way zero is referenced based on the main shaft. Imagine that your heli is sitting on a table tilting slightly forward. The main shaft would be tilited and so would the blades. The pitch gauge would read that you had a small amount of negative pitch on the blades at mid stick even though it was actually zero, because its referencing zero as the table and not the shaft. The shaft will be straight up once the heli is in the air, so that is the reference point. Does that make sense? |
#35 |
Ok thanks I understand what you mean now. Thank you for explaining it to me.
#36 | |
Just remember to zero it out each time you check something, especially if moving from checking collective pitch with the blades to the sides and then cyclic pitch with the blades over the boom/nose. Also I never check pitch on opposite sides. Figured I would get OCD about it and drive myself crazy. If it tracks well on the next flight (and it usually does) it must be ok.
#37 |
What digital pitch gauge are you using BTW? I'm seeing many not so happy people with the Align digital gauge. Looks like several are having issues with random and inaccurate readings.
#38 | |
#39 |
I'm using the align ap800 knowing my luck it's probably the worst one ever made lol.
#40 | |
Several are not happy and having to return them. |
