Old 01-06-2013, 08:38 AM   #1
shadco
Default Tail gain change when switched to SK Gov.
Mini Protos Sport flying head speed 3100
I got tired of the inconsistency using gov store mode with my YGE so I switched over to the SK Gov.
Good News SK gov works a champ but...
I noticed an oscillating tail wag similar to when I had logging on.
Tail gain was 46 and it was solid without the SK Gov, I dropped it to 36 and it seemed better, then to 30 and it seemed a little better.
30 is the low limit on my TX (T8FG).
Seems I can lock it in the SK settings to a value lower than 30 would that be advised or should I be looking elsewhere for the cause. Tail slider is buttery smooth and end points are spot on.
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 01-06-2013, 06:52 PM   #2
neoalchemist74
I would put your tail gain back up and instead try lowering your gov gain.
neoalchemist74 is online now        Reply With Quote
Old 01-07-2013, 10:08 AM   #3
shadco
You are referring to the gov gain setting in the SK Setup interface using either the 3d or advanced interface view right?
Currently set at 50
Old 01-07-2013, 10:33 AM   #4
neoalchemist74
Correct!
Old 01-07-2013, 10:33 AM   #5
snaaakeey
Gov gain on electrics seem to be between 25 and 35. 50 + seems to be for nitro.
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote
Old 01-07-2013, 10:52 AM   #6
shadco
Thanks for the tip, I was going to start at 40, now I'll try 30 instead and work from there.
I have the field programmer so it should be fairly easy to dial in.
Old 01-12-2013, 05:00 PM   #7
shadco
Gov gain at 30
Tail gain back up to 46
5 perfect flights today.
Old 01-12-2013, 11:34 PM   #8
neoalchemist74
