Old 01-06-2013, 03:26 PM   #1
sresener
Default Recently Swapped out a sk540 for a vbar
I had a head wobble in my x7 and that gave me a excuse to try the vbar.
I did find the vbar very easy to setup and the head wobble was completely gone.
I threw the sk540 in a 450pro and it flies amazing, even Alvin said its one of the nicest flying 450's he ever flew. So that means my wobble was a setting that I was to lazy to work through. .
I also find the vbar flies no better than the sk540.
To get to my point is, they are both great units just the sk540 cost me 225.00 and the vbar ran me 400.00 after the pro software. I wont be converting any other helis
X7, 600pro, X5, 500pro dfc, 450pro dfc, Tt e325v2, X2, 250dfc, 300x, 130x
Warp 360, goblin 500
sresener is online now        Reply With Quote
Old 01-06-2013, 06:35 PM   #2
gitbse
Also don't forget that the silverline vbar is the direct comparison to the sk540, they use the same sensors. The blue and mini vbar use the same sensor as the beastx. So consider that for price differences. $225 beastx, or $400 vbar, then $250 skookum vs 500 silver.
also, the only two on the market that use the new pinpoint sensors, are the sk720 black, and the spartan.
That means... ---beastx, vbar blue <sk540, silver vbar <sk black, vortex---.
Seems like game, set, match against vbar in my mind.
Skookum Support Rep
Mini Protos SK540,Rave ENV SK540, 4525 LE
Runways are for models and wings are for fairies.
gitbse is offline        Reply With Quote
Old 01-06-2013, 06:51 PM   #3
spikestabber
I've had this wobble on my 450 which turned out to be self tuning bell gains being not so smart....
Once SK updates the documentation and troubleshooting tips I expect there will be a lot less hair pulling.
T-REX 450Pro DFC, SK-720, CC Lite 50, TM1000, KDE 450XF, MKS DS95's, Futaba BLS-257, KDE, DX8
T-REX 700Ev3 DFC, SK-720, CC 160HV, TM1000, KDE 700XF, Outrage BL9180's/BL9188, KDE, DX8
spikestabber is offline        Reply With Quote
Old 01-07-2013, 12:52 AM   #4
dl5973
the sk540 does not use the same sensors as the vbar silverline. The Silverline uses same sensors as the sk720be, spartan vortex and futaba gy750.
skookum wont tell what sensore they are using but definately not the top of the range sensors like sk720 be. My guess is they use same senors as mini vbar but they use two sensors instead of one and that makes the sk540 perform so well.
dl5973 is offline        Reply With Quote
