Old 01-06-2013, 04:42 PM   #1
intensivist
Default Reducing Elev/Aileron Cyclic Mix% and hovering
I was trying to reduce the overall cyclic pitch in my Aileron and Elevator motions by reducing the Swash Mix fo the Elevator/Aileron Cyclic Mix% down from 60 to about 50 to achieve a maximum cyclic of about +/-8 degrees instead of 10. I left the Collective Mix% so that the maximum collective was +/-12 degrees
What I found after I did this was that I needed a much higher throttle stick setting before the heli would get light and hover. I was a bit puzzled by this because I thought that where the heli would get light depended on the throttle/pitch curves and the Collective Mix% and not the Cyclic Mix% settings.
I am using the SK720 on a TRex 250. It's a bit twitchy and I wanted to smooth it out without Changing a Dual Rate.
Should this have occurred?
Michael Hockstein
Trex 250 Pro, Trex 450, Trex 500 ESP
Skookum SK-720, Spectrum Dx7SE
intensivist is offline        Reply With Quote
Old 01-06-2013, 06:50 PM   #2
neoalchemist74
Yes that's normal. The unit will still use the full stick so what you are doing is blurring the resolution(for lack of a better term). I think what you want to do is soften your pitch curve in your transmitter and set the max pos. and neg. pitch with your transmitters pitch curve and a pitch gauge. If that makes any sense.
neoalchemist74 is offline        Reply With Quote
