| Aerial Videography and Photography Aerial Video/Photo from R/C Helicopters |
Hey all,
WellI knew you'd click here becauseof the word `crash` Nevertheless the cause is still a puzzle, I've been flying my T800 platform with Ace One , been doing several flights tuning in the gains.etc During setting up I totally ignored the Engine/Motor paged and left it on "Tx Electric", didn't go through the Max,Idle,Stop settings since I thought these are important only for gas/nitro setups. recently, I decided to go and try to do these settings since Ace View required these to be set in order to use the Go Home fail safe enhanced feature. So I do that, during flight, slip the switch to auto, and engine cuts off (from about 4 meters) slow decent with as much autorotation as i can on this low rpm, lead only to a landing gear break. Phew ! I've tried re-setting these parameters on the bench, still, activating autopilot shuts down engine, I've contacted DJI and they advised me to use a normal linear throttle curve before setting the parameters (max,idle,stop), still with same result. I'm using Futaba and throttle channel ofcourse is reversed, so I tried doing the opposite of the max,idle,stop, still didn't fix the problem. All I need is to know how did anyone set their Engine parameters in the DJI Assistant software if they're using electric motor (which mostly the case anyways) please? Last thing I resorted to and I dont know if this is how it should be done, is to set max and idle on full throttle, and stop on throttle cut. seems to keep throttle working during auto mode. Cheers |
I don't remember even touching those parameters as you don't need them for the electric machines.
My AceOne comes home fine. Just make sure you calibrate the TX so that AceOne knows where center stick is, which should be your heli's hovering point. |
That's what I thought too, I think I was confused on what I saw on the Ground Station software (the google earth like View) when trying to set Home position. A message appeared requiring me to set these settings. Apparently not. Specially since at that time I did not yet reach GPS calibration.
Thanks for your reply, helps alot heliaddx |
Hold up.....I don't use auto land or anything as such. I don't even use the Ace View so you might want to wait for other responses who have more of a similar setup to yours before testing it again.
nah, im not interested in auto land or auto take off , just the failsafe Go Home feature that doesnt even need ACE View, enhanced failsafe only needs the basic package from what I understand..
The Ace View though does communicate with the IMU and relays information, but your right, i'll wait and do most of my tests on bench. |
#6 |
Can you tell us what this T800 platform with Ace One is?
heli or multi? esc? LiPo count? motor? Radio system? so that we can better understand what is going on. Good luck, Ahmet |
#7 |
By T800 i meant Trex, actually a Trex700 stretched to 800, using Castle 160ICE HV ESC, XERA 400kv motor, on a 12S batt,
Radio is (my beloved) Futaba 12Z.. using ACE ONE dunno if the platform has anything to do with the motor setup of the Ace One though, but I just wanted to get the enhanced fail safe to work. |
#8 |
Apologies to the moderators too, I didn't realize there was a sub-forum for flight stabilization...
#9 |
Hi R-4-L,
your motor stops as soon as you "slip the switch to auto" ? I usually expect that to happen. No? Ahmet |
#10 |
I meant flip the switch to auto mode. (Autopilot mode)
Yes it acted like a throttle cut. Now when i set the Max and Idle (at engine setting page) to full throttle it works fine. Sent from my Nexus 4 using Tapatalk 2 |
#11 |
Did you confirmed the Tx center position in the enhaced failed-safe assistant page?
#12 |
Hi R-4-L,
this may be a "very silly" thing to ask but can you %100 make sure there is no mix that shuts throttle off in your TX? May be not eh? Sorry. Ahmet |
#13 | ||
To be absolutely certain, I am redoing the settings and will test the motor on bench today. and will keep you guys posted too. its something others might benefit from. |
#14 | |
Sometimes I am having trouble too setting Tx center, check in Tx-Monitor page if the stick gives the same read as you move them, if not, recalibrate sticks and then do the set Tx Center. |
