Closed Thread
Old 01-07-2013, 10:17 PM   #1
joveli
Default Skookum 720 and Gy520
Hi, can i use a external gyro (gy520) with my skookum 720 is it possible? thanks.
joveli is offline
Old 01-08-2013, 12:48 AM   #2
newbheliusr
Why would you want to do this?
Heli's I've had:MCX2, MSR, HB FP V2, Blade SR, 120SR, Trex 250, Trex 450 sport, MCPX,
Heli's I have:
Trex 450 pro FBL BeastX (Clone Mostly Align), Gaui X5(SK540), X7(Vbar)
newbheliusr is online now
Old 01-08-2013, 07:07 AM   #3
ICNU
The 720 already has one of the best tail gyros built in. There is no need for an additional tail gyro.
ICNU is online now
Old 01-08-2013, 10:00 AM   #4
joveli
Hi, cause one of my sk720 have problems with tail gyro
joveli is offline
Old 01-08-2013, 10:03 AM   #5
joveli
Hi, i know i have sk720`s on all my helis but one of them have problems with the tail gyro and i want test it with a external gyro like the small GY520 ...
joveli is offline
Old 01-08-2013, 10:06 AM   #6
ticedoff8
Send it back for repair.
If you really want to, you have to use an external receiver - no sbus or Spektrum sat receivers attached to the SK720.
You connect your gyro leads to the external receiver and then everything else would get hooked up as normal.
But, that really doesn't make sense. If the SK720's tail rotor gyro is FUBAR, then get it fixed.
ticedoff8 is offline
Old 01-08-2013, 10:14 AM   #7
ICNU
you can't do that if you are using the SK unit as a stand alone with sats. You would in essence have a gyro plugged into a gyro.
ICNU is online now
Old 01-08-2013, 10:48 AM   #8
georgi UK
=] what exactly is it not doing?
georgi UK
georgi UK is offline
Old 01-08-2013, 02:22 PM   #9
RC Mike
Yes it will work.
A few years back before Skookum had the tail firmware sorted out I flew my SK720 and a Spartan tail gyro and it worked great. I was using a separate receiver so I just plugged the tail gyro in the normal channels and did not hook up the rudder input to the SK720.
RC Mike is offline
Old 01-12-2013, 10:36 AM   #10
joveli
Default CLOSED
THANKS FOR ALL!!
joveli is offline
Closed Thread
