| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
Yes Tom. Using the sk gov on both 7hv's. tried the yge gov store on the e720 and it didn't even compare to the sk.
Using the kontronik s one in the warp and. X2 as its too easy. Ps. I have 1 of my yge 120's for sale on Rcha. You can have it at a special price?
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#22 |
OOOOW PM me Mr Heathy on rcha! See if my war chest can take this hit as well as the warp!
6hv (fb) 7hv DX8 |
#23 |
Registered Users ):>
Having I guess the same issue,
My gains at 22 and still doing it slightly. ![]()
700n To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Dan }:> |
#24 |
Heh at 19 now, Still kinda doing it.
There has to be a bug in the software with hobby wing esc's
#25 |
=] I don't have this issue running 100a and 70a hv hobbywings, are you guys selecting manage collective out of interest?
georgi UK |
#26 | |
Sent from The Pad of I
6hv (fb) 7hv DX8 |
#27 |
I will try now[
#28 |
Turned off the manage collective and my gains still needing to be low low low.
How low is too low in the gain? im in the teens and it just does it slightly.
#29 | |
6hv (fb) 7hv DX8 |
#30 |
I have tried something.
See pic below. I lowerd the Over ramp. and raised the high ramp. And it seems to be gone. And looks like I can turn up the main gain. I was in my yard so no 3d flight, but when i pitch pump and let off the head it does drop headspeed. Idk if thats normal. Guys might have luck trying to change these settings as I did.
#31 |
Awesome. Great job man.
Heli's I've had:MCX2, MSR, HB FP V2, Blade SR, 120SR, Trex 250, Trex 450 sport, MCPX, Heli's I have: Trex 450 pro FBL BeastX (Clone Mostly Align), Gaui X5(SK540), X7(Vbar) |
#32 |
I have this very same problem on my trex 450 pro . using the HW rpm sensor and sk540 internal gov. I just finally gave up and went with the gov on my YEP esc instead.
Perhaps one of sponsor pilots and shed some insight as to why this is happening on the sk540 gov
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#33 |
The 540 governor works great on Scorpion and CC esc in external governor mode. However we are looking into the issues people are having with HW esc. We will be doing more test and will try our best to find a solution for it asap. Sorry for the hassle everyone has gone thru.
#34 |
I had a tail wag on my Warp 360 using sk720 gov w/logging off. using the YGE esc.
I discovered that the tail wag went away after reseting the esc high/low throttle ends...where the LED on the esc goes out when at full throttle. When the led was still on at full throttle..i had the tail wag w/gov on.. just something to look at using the yge esc..if that is an issue with anyone... |
#35 |
Gathering info on your guys setups.
Do you guys have enough head room? for your 6hv's who evers having issues with that heli. as in 11t-12t pinions?
#36 | |
I think you guys should make me a consultant test pilot seeing as I seem to run head long into every issue going with the sk! Lol thanks for the heads up! Do you know if the yge esc are having any issues? Sent from The Pad of I
6hv (fb) 7hv DX8 |
#37 | |
Alivn above is the main man for skookum test piloting so its pretty much a sk software to hw issue. (Alivn put the tuning guide together and I also looked up some of his flight vids and he's not too bad..................; ) Sent from The Pad of I
6hv (fb) 7hv DX8 |
#38 |
Interesting. Any idea what the High Ramp and Overdrive settings do? I believe the Low Ramp is for the softstart, but could be wrong.
Greg ______________________________________________ Synergy E7 - Compass 600e - T500 - Trex Pro - mCPX |
#39 |
Ok,
So I tested the gov today. with gain at 24,(tail was still wagging a little bit,) It is consistent in stuff that requires alot of movement, but when you let off the head, you can tell it isnt working so well, Which is fine for now, its due to low gain. Once Alvin and the Team over at Skookum figure it out this thing will be a freaking beast. I am very happy with the unit overall, once the Gov is 100%. The unit will be one of the best out.
700n To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Dan }:> Last edited by frypan; 01-11-2013 at 01:47 PM.. Reason: Added a link to video. |
#40 |
A little birdie pointed me here.
http://www.rchelination.com/forum/sk...atter-wsk-gov/ So although my gov overhead should be enough on a 10t, an 11t pinion may sort it till a firmware update is avalible. If you have a look at the main skookum thread there, there is also a post by the same guy talking about the notorious elevator bounce some (me ) have had. This chap is a new team tester and like Alvin a very helpful chap indeed! Thanks guys for the info and I hope you and sk find a solution.
6hv (fb) 7hv DX8 |
