Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 01-29-2013, 04:57 PM   #1
keiser BLADE
Thumbs down 3gx problems
I have a 3gx on my 450 dfc , and it does full front flips on lift off into the ground, I spun the bird up with the head off and it has vibes, and the swash will drop a lot in the front, that was with the tail blades on and the main head off.
im just unshure on what to do, maybe try to balance this thing somehow
just looking for some tips
thanks Brandon
AMA # 618610
With Christ All Things Are Possible
keiser BLADE is offline        Reply With Quote
Old 01-29-2013, 07:35 PM   #2
bad007
Sounds like the elevator compensation is backwards. When you tip the helli the swash should try to stay level when being tipped and then it will return to level. Not seen as easy out of setup as in setup.
If you flipped it don't reuse any shafts or bearings. FBL isn't FB that doesn't care about vibes unless there bad enought to cause tail wag.
Align 450Pro 3GX Edge KDBB, Align 500 DFC 3GX, Align 500L MicroBeast Plus HobbyWing Platinum Pro V4 Plus Switch Blades, KST HV Servos, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle,
bad007 is online now        Reply With Quote
Old 01-30-2013, 12:34 PM   #3
nameci
I wouldn't call it a 3GX problem. Major vibration on the heli and/or improper set up of the heli/3GX...
http://www.helifreak.com/showthread.php?t=494746
nameci is offline        Reply With Quote
Old 01-30-2013, 12:41 PM   #4
BrokeBuyingHelis
Default 3gx problems
I had a lot of issues with my FBL setup on the 3gx an Nameci gave me some good points to eliminate the cause of my issue but what it mainly came down to was I did not run the DIR setup right and my Heli's swash was over compensating due to a drift, if I hadn't had it on a training gear it would have flipped also.
Best advice I got was make sure the tail servo is mounted correctly and run the DIR and rudder setup again, oh and upgrade to v3.0 which has a slightly different setup to the V2.1, so keep thy in mind.
GL
BrokeBuyingHelis is offline        Reply With Quote
