Old 11-10-2007, 09:05 PM   #21
chadjay
Originally Posted by Razor_Racer View Post
And I'm getting by with S75s just fine
I thought the S75 servos were good enough, but when I finally ran out of teeth (from stripping) I broke down a got the Hitec MG's. After installing all I could say was WOW, what a huge difference. The MGs work sooo much smoother and more in sync than the S75's. I guess you will have to experience the MG difference for yourself......
<<450SE V2, CC35, Kong Power 3S 25C 2200, 430XL, 401 w/9650, HS65MG, tail weight mod>>
<<Blade MCX with glow-in-the-dark setup, carbon fiber canopy>>
<<Yellow 600SNP, 8717s, 770 & 8900G, AR7100, Multigov Pro, Align 2 in 1(used for glow driver only)>>
chadjay is offline        Reply With Quote
Old 11-11-2007, 05:02 AM   #22
Pinecone
Typically if what someone is running works, they are happy. They just don't know any better. Once they switch, they see how bad what they are running is.
They forget, there is a reason that people give certain advice, and most times here on HF it is due to already trying what you are suggesting and finding that it works less well than the recommended method.
Take tail servos. Lots of people recommending the 9650 as he ulitmate, because that is what they fly. But those who have tried a 3400 or 9257 instead find they work better. Not that the 9650 doesn't wrk, it is just the others work BETTER.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 11-11-2007, 09:50 AM   #23
Razor_Racer
Yes, that is what is going on with me... I know the S75s are crap, but hey, right now they work for me so no use in upgrading
T-Rex 450 SA
V1 head / 430L / 35G / DS285s / GY401-HS56 / Hextronik D9 G3 2200mah / AR7000 / DX7 / Cheapie $12 CFs
Razor_Racer is offline        Reply With Quote
