Old 03-13-2013, 11:49 AM   #1
Diogenes
formerly koi-fish
Default High pitched whine?
I've noticed this on my hoopty bird that I recently put a Microheli frame on. This thing flies like its on rails, no problems at all, no vibes, etc but I'm noticiing a high pitched whine, different from the sound of my HP08 in it. All bearings, motor, etc have been oiled.
Anyone ever see this with a MH frame build (is it normal)? I did have to add shims, 6 iirc to limit up and down play. Do too many shims cause a noise like this?
The other 130x doesnt have this noise other than the different characteristic whine of the HP08 doing its thing. That is, when I'm not messing up by taking chances, i.e. inverted outside of my comfort zone
/ 130x, 180cfx, 300x, 360cfx, X3, x3L, X4-II, Protos 380 (in transit), x5, Gob 500, Warp 360, 450x, forza 450ex, DX18, 07 Harley Road King/04 Sportster, Traxxas Summit/E-Revo/X-Maxx, Vaterra 67 Mustang Need Forza 450ex head and tail boom/tail assemblies - thanks!
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is online now        Reply With Quote
Old 03-13-2013, 11:54 AM   #2
jrwalte
Is it the main gear mesh with the pinion? Or a A/B/C/D mesh too tight or TT rubbing.
jrwalte is offline        Reply With Quote
Old 03-13-2013, 12:02 PM   #3
GravityJunkie
Are you talking about the tail whine when pushing it hard during certain flight? Mainly during sideways flight like fast, aggressive funnels. This is with the stock frame.
My X2 does the same thing.
GravityJunkie is online now        Reply With Quote
Old 03-13-2013, 12:13 PM   #4
Diogenes
formerly koi-fish
nope, pretty much any flying, slow, fast, loops, etc. It does have metal a/b, maybe I have too many shims on it. c/d are kept stock for point-of-failure
Old 03-13-2013, 03:37 PM   #5
GravityJunkie
If you think it's a gear whine, pull off all the blades and spool up. If needed, you can work backward to find it.
Old 03-13-2013, 08:48 PM   #6
flatthump
It happens predominantly on positive pitch maneuvers, its the left tail case bearing taking all the load. It helps to shim between the right side tail case bearing and the D gear. doing that with a metal tail case will help more too.
flatthump is offline        Reply With Quote
