Old 04-03-2013, 09:02 AM   #21
rwpielet
Out of sheer frustration I bought a brand-new 130x. Out of the box, it flew perfectly with the stock tail servo. I then installed a brand-new DS35 and it started wagging like crazy. I Tried adjusting the tail gains and the position on the servo horn. Still no improvement. I know I should just use the stock servo, but now I'm on a mission to sort this out. Horizon Hobby said I could send them back to be evaluated. It seems odd that I would get 2 bad brand-new servos. Is there any other manufacturer that makes a comparable sub-micro servo that I could tr.y? Or any other suggestions? Thanks for all the help so far.
rwpielet is offline        Reply With Quote
Old 04-03-2013, 10:52 AM   #22
Meekrakkin
Moved to the middle hole on the horn... (was on the inside)
I'm at +5 on gyro gain and the tail is locked in solid on full pitch pumps at 110% pitch travel adjust (HP08 and 10t pinion).
I had to reduce tail gain to -4 with the stock servo when I put the HP08 in and it never really felt locked in to me... this setup is WAY better
The feel of the tail is faster but smoother than with the stock servo.
T-Rex 700E DFC Pro HV, Blade 500X, HK450 ProV2 FBL (Tarot DFC Head, Tarot DFC Swash, BeastX, Align Blades), mCPX BL (Every RKH Upgrade, KDE Blades, Lion Heli Canopy, Gear and Fin), 130X (Custom build... nothing stock), 300X (Edge Blades)
Meekrakkin is offline        Reply With Quote
Old 04-03-2013, 11:04 AM   #23
Meekrakkin
Make sure your linkage is super free... the DS35 isn't as strong as the stock servo so any binding will show up more and cause problems.... here's my linkage
Old 04-03-2013, 04:32 PM   #24
Alex4R
I just straightened out my pushrod to almost perfect (although I think the dampeners on the tail grips bind more than anything), changed my rudder gain to +5. Still on the inside hole on servo horn. Tail wag is almost non existant! It blows out on pitch pumps and may have a slight mini wag as it returns to center. Finally, now we're getting somewhere.
P̛͞͞r҉̵͜͡o̸̷͘͘͢t̴͢͡o̕͜s̴̨͜ ̵̵̛͜5̧҉0̧͞͡0҉͢͟͟
Alex4R is offline        Reply With Quote
Old 04-03-2013, 04:48 PM   #25
jmisuraca
Default tail wag with DS35
The inner most hole does not give enough travel to prevent the BO.
A lot of RC stuff:
Heli's, Quads, FPV gear, Tools, Chargers, Transmitters
jmisuraca is offline        Reply With Quote
Old 04-03-2013, 07:48 PM   #26
dougiefresh94
Did you put the microheli tailblades on the new heli, or leave everything stock, but the servo?
dougiefresh94 is offline        Reply With Quote
Old 04-04-2013, 03:06 AM   #27
Meekrakkin
Yep... middle hole is the best.
Also after I straightened out the pushrod I had to reduce gain to stock and it still wags just a touch on a fresh pack. Not enough to keep me from flying... just a nuisance.
I'll try -1 tomorrow and see how that goes
Old 04-04-2013, 08:30 AM   #28
jmisuraca
Last night I pulled the working rudder servo from bird number two. And what do you know bird number one flies like it's on rails.
A lot of RC stuff:
Old 04-04-2013, 11:10 AM   #29
Meekrakkin
Messed around with gain settings today...
Stock = slight wag
-1 = moderate wag that calmed down as the battery settled in
+1 = locked in no wag
+2 = locked in with very slight wag on severe pitch pumps
looks like +1 is my number
Old 04-04-2013, 11:19 AM   #30
tmsn
I swapped the stock push rod with the extreme designs carbon push rod and it still wagged. I then tried amping up the rudder gain and the wagging stopped at +5. Seemed to hold through pitch pumps in my garage last night. There is a little wag but it's now tiny. Let's see how long it holds later today at the park.
tmsn is offline        Reply With Quote
Old 04-04-2013, 11:53 AM   #31
nartac
Weird. I just received a ds35 replacement from HH. My old ds35 stripped gears and I don't have replacement gears for it so put in the brand new ds35 and it starts wagging as well despite gain adjustments. This really sucks. I'm going to my lhs and get some ds35 servo gears and see how the old one works
nartac is offline        Reply With Quote
Old 04-05-2013, 10:03 PM   #32
SYMAWD
I just installed a DS35 today. Using the small cross arm (the one with only one hole per arm), and +5 gain gives me just a tiny wag after hard pitch changes. I might need to go to +7 or so to get it perfect. The more I raise the gain, the tamer the wag. I just need to play around with it a bit more to get it perfect.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote
Old 04-06-2013, 01:55 PM   #33
SYMAWD
So, I can't get rid of it. Anything - in gain gives bad wag. At +8 it is perfect, but once I give a decent amount of pitch, it wags, and +9 and +10 give it wag all the time. Then while testing, my B gear flew off in flight. Another $12 down the drain.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 04-06-2013, 07:22 PM   #34
Alex4R
Default Re: tail wag with DS35
Same here.
Tried a 3rd new one today, straight from horizon. It was worse than the one that came in last week.
I'm going to drill some more holes in the servo arms for the pushrod and see what happens. If that doesn't work I give up.
Has anyone asked horizon why they made a running change with these?
Tapatalk 2
Old 04-06-2013, 09:13 PM   #35
jmisuraca
I bet these new servos are just too slow with the low voltage. I bet if you can supply 4.8v the thing would be fine.
A lot of RC stuff:
Old 04-06-2013, 11:45 PM   #36
nicholask1993
Sweet, more money down the drain thanks to Horizon. Maybe those Hitec servos announced around the time of the MH rotary frame will actually work...
nicholask1993 is offline        Reply With Quote
Old 04-07-2013, 03:37 PM   #37
tmsn
Ok. The good news is that with the DS35s, for the first time in months I've been able to put my whole battery bag through my 130X without crashing due to tail blow outs or other tail related problems. The bad news is that there's always wagging, and the required gain to cancel the wag is very sensitive. Changing tail blades will probably require adjusting the gain, for example. Maybe even wear on the gears too.
Right now I've settled at +3 gain. Using DS35 with th Extreme carbon push rod, and stock plastic pitch lever and slider, lynx blades all around, and red o-rings everywhere.
Tail wags very slightly on hover, a little more after pitch pumps, and can get into a noticeable wag when in FFF. But, the tail simply wil not blow out as much as I try, so I am always in control. As a result I've flown about 15 batteries in a row without a single crahs for the first time this year.
I'm frustrated at these servos but at the same time I'm really happy I'm able to fly at all.
Old 04-07-2013, 03:56 PM   #38
SYMAWD
Clean your stock tail servo. I bet the blow outs will stop.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 04-07-2013, 07:37 PM   #39
Gonzohf
Similar story here. Got DS35 finally, installed with micro heli brace and pigtail. Tail wags like crazy. Gain up, gain down.....same wag! Noticed some binding between main gear and motor pinion. Replaced main gear at LHS advice and noted not a good mesh between them so asymmetrically shimmed main motor on mount to move closer to main gear. Not perfect but much better. Still tail wag! Put crappy old tail servo....voilà, wag gone. I have residual left yaw at center stick that I can center with 3 clicks of trim on my DX6. Now what do I do? This thing will drive me to the poor nut house!
Gonzohf is offline        Reply With Quote
Old 04-07-2013, 07:59 PM   #40
Hydros27
Does anybody have the new version of the DS35 that works right? I have the old version and it is great. I would like to be able to replace it someday when it wears out.
Hydros27 is online now        Reply With Quote
