Old 09-11-2009, 08:51 AM   #21
shaggybirdman
cool. now if i want to shorten a wire i just cut it, and seal the end with shrink tube, glue, or anything to keep moisture out?
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, DX7
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
Jerry
shaggybirdman is offline        Reply With Quote
Old 09-11-2009, 09:41 AM   #22
rdlohr
Pretty much. Make sure the filiments don't short to the core wire though.
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is offline        Reply With Quote
Old 09-11-2009, 09:46 AM   #23
rdlohr
Originally Posted by flyinfool View Post
Yes, all 4 tiny wire ends can be soldered together at the splice.
You might notice slightly less light at the joint.
To be more like the original wiring, would it work any better to solder each filiment on the first wire to a filment on the second wire rather than soldering all four together? It could be that it makes no difference at all.
Rick
Old 09-11-2009, 11:47 AM   #24
flyinfool
You will be hard pressed to even find the difference let alone notice it in the air.
There will be a slight reduction of light on the side of the wire that does not have a filament wire only in the immediate area of the splice.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
flyinfool is offline        Reply With Quote
Old 09-11-2009, 08:24 PM   #25
rdlohr
Cool
Rick
Old 08-25-2010, 05:34 PM   #26
Ironizer
I have a hard time stripping the insulator off from above the two very thin secondary wires without cutting them. Any tips?
What if I solder only one of them (because the other one has been cut)? Will the string be dimmer?
Ironizer is offline        Reply With Quote
Old 08-27-2010, 05:25 PM   #27
flyinfool
It helps to use a slightly dull knife to strip the outer insulation without cutting the fine wires.
Also do not cut all of the way through the outer insulation, you just need to score it and then you can break the last little bit as you pull it off.
It does take some practice.
Using just one wire will give you a barber-pole effect with light and dark strips.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
Old 09-16-2010, 01:09 PM   #28
citium
Default Can you use 240V instead of 120V
I have a 6 Cell battery and I know connecting it to the inverter will produce somewhere around 240~AC. The glow wire I believe are rated for 120VAC.
Will my glow wire burn up or my inverter blow up ?
citium is offline        Reply With Quote
Old 09-16-2010, 08:59 PM   #29
flyinfool
The inverter will blow pretty quick at that voltage. It will also reduce the life expectancy of the wire.
It should be bright, can you say flashbulb?
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
Old 09-21-2010, 04:38 PM   #30
wolfman76
what i s longest amount of string light per transformer i am thinking of the el light strings you can put in cars is this the same type of string light as wg light and other required components... any help would be greatly appreciated i appologize for being such a noob at this stuff like other things in life this is a learning process.. thank you
wolfman76 is offline        Reply With Quote
