Old 05-03-2013, 09:32 AM   #1
colcha
Default 700 Helis - Spare Parts Cost Comparison
I have often wondered how various 700 sized machines compare to one another when it comes to spare parts costs. To satisfy my curiosity, I have put together a spreadsheet comparing a cross section of parts across various 700 helis which I thought may be of interest to others:
https://docs.google.com/spreadsheet/...mc&usp=sharing
When reading this spreadsheet, the following should be kept in mind:
  • I have only chosen parts that are common to all helis eg. I have not listed torque tubes, belts, intermediate gears, etc.
  • this is not intended to be an exhaustive list of all the parts that are likely to break in a crash
  • prices are based upon a single unit eg. items such as shafts are often sold in pairs.
  • I have not taken into consideration the fact that the same part in different helis may be less susceptible to damage in a crash eg. boom on a Goblin, upper frames in a 7HV
  • whilst this list is not exhaustive, it does give a general idea of spare parts costs for a particular heli relative to other helis
  • there are a number of 700 size helis that I have not listed (eg. Whiplash, Faifa, etc). If there is interest, I might add more helis at a later time.
It is interesting to note that spare parts costs for the E720 (the most expensive heli):
  • was than 50% higher than the cheapest heli (700DFC); and
  • was higher than the TDR (even though the E720 is mass produced whilst the TDR is hand made)
Trex 550, Synergy E5, Logo 600, Synergy E7 and TDR
colcha is offline        Reply With Quote
Old 05-03-2013, 09:40 AM   #2
stevehof
Very informative, Thanks!
Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition, Rail 716, CC120, WR Sup BEC, Scorp BUG | Trex 450L, Vbar Pro, MKS 8910A+ on tail, Talon 35 | Futaba 18mz
stevehof is offline        Reply With Quote
Old 05-03-2013, 09:40 AM   #3
seefest
Nice compilation. One correction, the Goblin boom is $70 not $95 as listed.
TDR parts are relatively reasonable.
GOBLIN 570 12S JIVE 120, BK CYCLIC, BK TAIL, PYRO 650, CYCLONE, SK540
GOBLIN 700 COMP HELIJIVE 120, RJX CYCLIC, BK TAIL, PYRO 750-500, CYCLONE, SK540
LOGO 600SXJIVE 120, MKS SERVOS, SK540, RT MAINS, CYCLONE TAILS
seefest is online now        Reply With Quote
Old 05-03-2013, 09:44 AM   #4
colcha
Good pickup. There appears to be more than one boom available for the Goblin 700! I have now listed the cheapest option.
Old 05-03-2013, 09:48 AM   #5
Slyster
Nice work! Another thing, the Goblin booms are designed to crash... tough and break away.. so usually pop off and are usable again. Take that off the chart and the Goblin is actually the cheapest 700 to repair
Can you add Avant? (curious.. a friend of mine just got one)
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 4010Duo / Deep cycles
Slyster is online now        Reply With Quote
Old 05-03-2013, 09:49 AM   #6
Glenn Goodlett
Some eye opening findings, thanks for posting. I would like to see others like epic, TSA, whippy, etc.
Glenn Goodlett is online now        Reply With Quote
Old 05-03-2013, 10:18 AM   #7
Colonny5
If you add more, add AleeS to the list.
Lynx Team Pilot
Colonny5 is offline        Reply With Quote
Old 05-03-2013, 10:40 AM   #8
Jeff_Barrett
It's a neat design when it works, the problem I encountered when the boom popped off was that it had a 50/50 chance of being struck by the main blades and getting damaged that way.
Similarly, as the OP pointed out, the 7HV frames are designed that the lower frame will break in most crashes leaving the upper main frame which contains all your components in tact and a smaller repair bill. This doesn't always work out and the upper frames can be damaged as well.
Nicely done on compiling the list!
Slyster made a similar comparison for the 500 class models a few years ago.
Jeff_Barrett is offline        Reply With Quote
Old 05-03-2013, 11:32 AM   #9
colcha
I have now added the following helis to the spreadsheet - Aurora, Rush, Whippy, Srimok and the Diabolo.
I should also mention that the parts prices for the Diabolo is inclusive of 19% European tax. This tax is not charged for orders shipped outside of Europe.
Some interesting observations:
  • although the Aurora is often seen as a high end machine, parts prices are quite reasonable;
  • parts prices for the Whippy are significantly above those for more mainstream helis.
Last edited by colcha; 05-03-2013 at 11:51 AM.. Reason: TDR prices are exclusive of 19% tax
Old 05-03-2013, 12:31 PM   #10
dankcincy
Had to
dankcincy is offline        Reply With Quote
Old 05-03-2013, 04:16 PM   #11
ronm3313
Thanks for the info
AMA: 943183, DX8, Tarot 500 ESP DFC/Vbar, Goblin 570/Brain, Blade 180 CFX
ronm3313 is online now        Reply With Quote
Old 05-03-2013, 06:04 PM   #12
Crowbar
Very interesting indeed. Around here in Germany, goblin parts seem to be about 2x the price of 700DFC parts so flying a Goblin around here makes little sense financially. If you're at a point where you don't really crash anymore, then it makes sense to go for Goblin. I just think they look sweet.
Crowbar is offline        Reply With Quote
Old 05-03-2013, 07:59 PM   #13
mkovalcson
The elephant in the room is that they don't all crash the same.
For example a TREX 550 main gear is pretty cheap and a Synergy E5 main gear is pretty expensive, but the TREX 550 main gear was destroyed in every crash I ever had and most people are reporting that their main gears on the E5 rarely ever break in a crash.
Helis like the 7HV, TDR, Diabolo have upper and lower frames so crashes can be cheaper because of that and more importantly take a lot less rebuild time since the main components don't all need to be remounted, and time is money too!
The e720 may have expensive parts, but it has a 15mm main shaft which also tends to take a lot of pounding without being damaged. Other parts are likewise very durable.
By the time you add in the additional $150 for main and tail blades most 700 series owners use, the prices get even closer.
Information is always good, but personally I don't think a comparison chart like this has enough information to really gauge how much each heli will cost to repair without having crash tests and seeing how much is damaged in each test.
If you see how often a 15mm main shaft fails compared to a 10mm main shaft, or a 10mm feathering shaft vs. an 8mm feathering shaft.
There are the crashes that you can walk away from and spin up on the bench and find all the vibrations look normal in vibration analysis and you know all your bearings are intact and all your shafts are still straight.
Just saying that people tend to look at charts like this and point to part prices that they like or don't like about their favorite model and then try to use the numbers against other makes and it really isn't enough information to do that.
Mark
frequent fliers: Henseleit TDR, Protos Max V2, Henseleit TDR2 - backup team: Protos 500, Logo 550SX
Charging Tower / Battery Caddie Thread
mkovalcson is online now        Reply With Quote
Old 05-03-2013, 08:31 PM   #14
Rahulgaba
Went in full throttle on my whippy.. Soft ground but that doesn't save the big ones by that much
My damage was : blades , landing gear , boom, main shaft, (not even torque tube)
That's it
While I appreciate you taking the time to compare prices but the crashability is different ... My repair was a total 190
Whippy survived like a champ!
So yes 700's are expensive .. But not all break everything.
This is not always true (not dissing your work) but .... Not all helis crash and break same
Whiplash 700 Gasser TRM VX300TT
Whiplash Nitro 91 HZ-R 3D & Hitori
VIBE 50 big block OS 91 HZ-R IKON
JR X9503
Blade 180CFX Gaba
Rahulgaba is offline        Reply With Quote
Old 05-03-2013, 08:54 PM   #15
seefest
Did you guys read the OP's post? He clearly states its not a crash comparison!
Old 05-03-2013, 08:57 PM   #16
seefest
Your 550 stripped main gears because you're unable to train yourself to hit TH..........you've stated so yourself in several threads.
Old 05-03-2013, 09:57 PM   #17
mkovalcson
There you go. Not only to helis crash differently, but people crash differently.
FYI, in my last TDR crash I hit TH in time and didn't strip one gear or bend one shaft, but I still toasted my main blades, 3 bearings, the boom and right landing gear.
Hopefully that will be the last ouch for a long time now that it has a flight deck.
Time will tell.
"Did you guys read the OP's post? He clearly states its not a crash comparison! "
That's irrelavant. Look at the posts that turned into a this crashes this way vs. that way, i.e. Goblin tails and Compass bottom frames. Every time a grid like this is created people convert that to crash costs.
What really would be any other purpose for such a grid? You could just post the kit costs side by side and have information that was just as useful.
Mark
Old 05-03-2013, 10:24 PM   #18
flyinghigh450
That of gear mesh isn't correct..Crashed the crap out of my Trex 550 over 10 times and stripped the main gear once,all hard crashes at 2300RPM or 2500RPM and thats with the old 170T main gear.
I stripped the main gear once out of 18 crashes on my 600EFL Pro which was expected because that was a rekit lol...Bunch of hard crashe and thats with the new slant 112T gear..Its the same gear used on the 700E getting 9000-11000 watts put through them with no strip,same gear on the 550...Something isn't right if someone is stripping them,
Team Align
flyinghigh450 is offline        Reply With Quote
Old 05-03-2013, 10:57 PM   #19
perlinauto
+1
mCX, mSR, 250SE 3GX, 450PRO AR7200BX ,500ESP 3G, mcp X, 450SPORT 3G, 700E V2 3GX, 500EFL PRO 3GX, Walkera V120D02S, 550E V2 3GX, 250 PRO DFC 3GX, Wakera Mini CP, 450PRO DFC 3GX, Blade 130X, Blade mcp X BL, Warp 360, DX6i, DX8, 2801 pro, Devo 10
perlinauto is offline        Reply With Quote
Old 05-04-2013, 03:15 AM   #20
colcha
Is this spreadsheet intended to be a definitive comparison of crash costs between different helis? Of course not there are lots more variables to consider. As you correctly point out, every heli has its own weaknesses and every crash is different. Additionally, I have only listed some of the parts that may need to be replaced in a crash.
The intent of the spreadsheet was to give people a general idea of the spare parts costs of one heli relative to another. For many, this is an important consideration when buying a new machine.
If people wish to use this information as a starting point to undertake their own analysis of the potential running / crash costs for a particular heli, there is nothing wrong with that and people are smart enough to take into consideration other relevant factors eg. sacrificial lower frames, breakaway booms, etc.
I agree that the Delrin main gear on the E5 is stronger than the plastic moulded gears on the 550e. What you fail to mention is that 1 main gear on the E5 will buy you 6 main gears on the 550e. As strong as E5 main gear is, I am not so sure that it would survive 6 crashes unscathed.
The fact that an e720 uses a 15mm main shaft does not automatically make it better than another heli that uses a 10mm main shaft. There are other considerations including the length of the shaft, the design of the shaft (hollow, solid, etc) and the materials used.
Yes and no. In a decent crash, you may end up breaking a lot more parts than I have listed in my spreadsheet. The cost of those parts on a 700 can add up quickly and form a significant part of the overall repair cost. Take canopies as an example. The cheapest canopy in the comparison was $64.99 whilst the most expensive canopy was $134.99. That is a significant difference.
Two people can look at the same set of data and draw vastly different conclusions that happens in all facets of life (just look at politics!). However, that does not mean that such data is not helpful so long as its limitations are recognised.
Not really. The way in which heli kits are priced is similar in one sense to how both razors and computer printers are sold ie. there is far greater margin on parts than there is on the original product itself. Consequently, the price of the kit is not particularly helpful in determining future running costs.
