| Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
This is the place to post your 14MZ, FX-40 & 12Z files. Please share them, as we all can learn from one another.
Eric To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
This is a basic ECCPM Model setup. The reversing and servo layout is set for Miniature Aircraft Helicopters.
This setup uses a GV-1 governor set to "off" in normal, and 1750 in idle up 1&2. Also it is set up for the GY601 gyro in AVCS mode at 38%. Switch E is condition (Idle, 1, 2) switch F is governor off override, switch G is throttle hold, Switch H is throttle cut when the throttle stick is at idle. The setup is very simple and a good base point to work off of.
Thanks Eric
I just got my 14MZ today. I have a Spectra with 601 and GV1 I'll let ya know how close it is on the spectra and if I need to make any changes I'll post them. Also have you noticed that the throtlr stick doesnt appear to go full travel ?? Mine doesnt go all the way to the last white index mark.
Craig Alias Racer38 MA Fury Extreme Worlds Cheapest 450 Electric HK450 HK-500GT Build coming soon. HK Build Info at http://hk-helis.com |
The throttle stick travel is reduced in both the 14MZ as was the 9Z. You notice it because the lines do not line up, but they are the same travel. It took me a while to get use to it as the 9C has full travel. Don't ask me why they did that, it is just the way it is. If you want full travel, you need to send it to Hobbico and have them remove the limiters and recalibrate it. I still may do that, I just do not have the time now. I really can not say if I like it reduced or not, it is just different.
Ya let me know if there is anything messed up in there! I think that setup is pretty decent, but for some reason we loaded up one and the gov was reversed, but worked in my radio fine... not sure what happened there. Good luck and let me know how it is going!
Program for DYNA - X with YS 91 and 1:8 gearing
GY601 @ 38 % on sw F on and off @ normal 50% TJ PRO : off @ normal curve expo on 1760 @ idle 1 V-curve on 1850 @ idle 2 V-curve together on idle sw C Trottle hold @ sw G Trottle cut @ sw H Expo aileron -30% D/R 80 % elevator -30% D/R 80 % ruder -20% D/R 100% Channels: 1 aileron 2 elevator 3 Trotle 4 ruder 5 gyro 6 governor 7 pitch Best regargs Sapca |
#6 |
Here is my Spectra G Picture, This Radio is soooo Cooool
#7 |
Is anybody out there with a raptor setup?
Manuel :?: ![]() |
#8 |
I could easily mod my setup just a bit and get it right for standard mix. The rest of the setup will be the same. I will see about doing that tonight or tomorrow.
later,
#9 | |
Later; D.W. |
#10 |
Eric,
By chance do you have your Ion-X model that we could download I know it is very close to the same as the fury one you done but the Throttle curves and we don't need the Gov part David
ReadyHeli Field Rep Thunder Power Field Rep |
#11 |
Sure, when I am home later I will post it up.
#12 |
Thanks Eric
Your the man
#13 |
D_Wheel,
Thanks a lot. Does anybody have sound bits files? Manuel |
#14 |
Hi,
hope someone finds them helpful
Thx, Yours Henning Piez |
#15 |
Here are my contributions so far.
Reflex Sport 90 Setup Ion-X Single Stage Actro 32-3 77-O-H Ion-X Dual Stage NEU 1521 77-O-H TREX CCPM NEU 1107 Jazz ESC Lark 3D Plank 4 mode pretty cool Plus a few of Shannon's Models... You guys have nay models you want to share? Lets build up some starting points for people getting the KILLER 14MZ! Thanks in advance for sharing!!
William James To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. If you fly you are going to crash. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#16 |
These are my files for the 3D MP, Avant EFX and Hirobo Mini Lama.
Please note that all of them are in mode 1. - The Avant is setup for the Gy611 and TJ Rev Max so idle up 1&2 have a straight 100% throttle curve. - the 3D MP is setup for the CSM 720. Both of them are setup for 0° at center stick and have a linear pitch curve. The difference beethween idl up 1&2 is that in idle 2 you have a slower tail. bye Iacopo
Synergy N9 |
#17 |
Any more sounds out there?
/Fredrik __________________ X-Cell Stratus 3D V-bar Logo 600 3D V-bar TT Mini Titan E325, Z-Power Z10A, Jazz 40-6-18 |
#18 |
hello everybody
does anyone has a setup program ( file mdl) for 14mz, program to work with a vario bell222/230 or airwolf... thanks |
#19 |
Hello All
Anyone have a 3d Setup for a Century Preditor?????? Thanks Ross |
#20 |
Anyone have something that would work, or a program that I can mod for the Pred?
Thanks Ross |
