| Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
#21 |
The JK ECCPM model would be a good start. I think it has GV-1, GY601, and pretty much all the conditions setup.
You would probably need to change servo reverse where applicable and the swash settings (I don't have a predator - don't know if its CCPM or not). That would get you going pretty far, as would any of the models listed above. 90% of the programming is the same between helis for a basic setup. Mike...
Good Judgement comes from experience, Great Judgement comes from bad experience. |
#22 |
Thanks Mike :glasses2:
New to Set-ups! I will start there!Thanks Again! Ross |
#23 |
Any TREX SE450 "Stock" setup?
#24 | |
William James To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. If you fly you are going to crash. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#25 |
Here is my Stratus setups that I use for both, I have included both my pictures.
Also included is a reflex xtr bmp My setup is :- GY611 + 9256 servos 9255 all round +10 to -10 on all modes +10 to -6 on throttle hold (on switch g) revlock with set at 1700, 1850 & 1900 (on switch e) revlock off (override on switch d) throttle cut on switch h |
#26 |
does anyone have a 14mz file for a raptor 50 with a 401 in mode 1 ?
no govenor fitted ? thanks Dale
FAIFA Logo 600 3D |
#27 |
What are the chances of these programs working for the 12z?
My understanding is if the model name is 8 characters or less it will work? (Thanks in advance Sapca!). Blair |
#28 |
Here are some of my sound files.
You can make your own custom sound files using: http://www.research.att.com/~ttsweb/tts/demo.php -Eric |
#29 |
Hello everyone
does someone has the setup for hirobo sceadu 50 evo ( normal and idle-up ) ? My setup is : os 50 hyper gy-401 + 9254 9255 cyclic 3050 gas regards, Jack |
#30 |
Following italian voice files (female) for various conditions (startup,idlup1,idlup2, hold, normal)
Luca |
#31 |
Following my setup file for the following models:
- Thunder Tiger Raptor 90 SE with GY 611 and RevLock - Thunder Tiger Raptor 50 Titan with GY 611 and TJ Pro - Hirobo Lepton EX with Jazz 80, GY401+9254, Hyperion 3025-10 - Twister 3D Pro with Align 35 ESC, Gy 240 All setups are in mode-1 Luca |
#32 |
Any chance someone has put their Blade CP or CP Pro on their 14MZ and would be willing to share?
Since I'm totally new to helis, I'm lost on my 14. Seems like such a waste! Any guidance would be greatly apppreciated! -bob |
#33 |
Here are a few WAV files I've created. I've included a few for the trainer box. :wink:
Feel free to make suggestions. Bill Vail
"Well, Nothing bad can happen now." |
#34 |
Anybody got a setup file for the Blade CP or the T-Rex 450XL and 450SE?
THANKS! |
#35 |
heres one for a blade cp pro
Team Cajun helicopters Team No Turds..................! |
#36 |
Hello guys,
I own two old helis BUT I need assistance on how to setup them on my Futaba 14MZ radio (mode2). Does any fellow have the Trex 450X and the Raptor 30V1 files ? my Trex is with Hitec 55s and Fut GY240 gyro and the Raptor an old setup from '99 which was never flown (CSM 2000 gyro). I appreciate any help ... Regards |
#37 |
Here is my setup, mode 2
for Century Predator Carbon Gasser 26cc gy611, gv1+9252, S9451. Trims are inverted. SA=GOV on/off SB=AILE/ELEV d/r SC=GY sens SD=rudd d/r SE=GOV 1500/1750/1850 SF=NORM/IDLE-UP SG=THR HOLD SH=THR CUT LD=GOV +/- 50rpm CD=Audio volume RD=GY sens +/- 5%
FUTABA 14MZ To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#38 |
Hi
I need Jetcopter SX setting. It's not easy to setting up correctly by myself. Please share your setting. Thank you :wink: |
#39 |
I'm not using my 12z until the spektrum modue comes out, but If anyone gets their trex600 nitro setup, could you please post the file.
I'm using multigov, 401/9254, and 9252's on cyclic, but anything to get me close will work. This will be the first model on this radio and It will help a bunch to look thru the programming for the next setup.. |
#40 |
Here are some of my 14 MZ model settings (mode 1):
Important: I use a tray system with my 14MZ. I reassigned Throttle hold to switch B and the condition switch to C. First a T-REX 600 set up with a Jazz controller and the standard Align 600L motor. The second one is a Freya Twister. You will have to set again the different swash mixing compensation for your head as mine really needed a lot of compensation... I use a multigov on it but the throttle curves are set and can be used without it. Then the third one is a Freya Super II (standard Freya with SSR-VII head) with a Staysee body set for F3C. I use the throttle mixing (no governor off course) and needle curve. I am experimenting with these needle curves and will probably inactive them shortly. Everything else is standard setting. Enjoy! :wink: |
