Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 03-09-2009, 11:00 AM   #61
Turbineman
Does anyone have a E-flight blade 400 setup for futaba 14MZ I have tryed to do myself is like Thanx Bob
Turbineman is offline        Reply With Quote
Old 03-09-2009, 02:03 PM   #62
DavidH
http://www.14mz.com/downloads/index.html
Plenty of different models available at the above. Just have to choose one and then make adjustments to suit the model your setting up.
David
DavidH is offline        Reply With Quote
Old 04-03-2009, 08:33 AM   #63
Karmann
David
This is only true for US 14MZ owners since those are the only ones allowed to register.....
Karmann is offline        Reply With Quote
Old 07-13-2009, 07:27 PM   #64
Dave Willis
Question Download files
How are these files downloaded and used. I can't figure it out. Maybe I don't have something I need. (Probably enough smarts)
Thanks.....Dave
AMA 6679
IRCHA 675
Dave Willis is offline        Reply With Quote
Old 05-11-2010, 05:27 AM   #65
gumush
Any one have 14MZ Trex 3G setup ?
gumush is offline        Reply With Quote
Old 05-11-2010, 10:39 PM   #66
aussiemick
I do, I have it for a 700N, 600N, and a 250.
Mick
aussiemick is offline        Reply With Quote
Old 06-04-2010, 10:18 PM   #67
neavissa
Hi there,
I tried to edit my picture files, converting them to bmp and so on but I cant figure out how to make them work on the 14mz?! Any ideas?
thanks,
G
neavissa is offline        Reply With Quote
Old 08-03-2010, 02:57 AM   #68
Steve M.
Default Program for reading/printing the files?
Does anyone have a way of reading the .mdl files so they can be printed for easy viewing for reference?
I saw one program on the web that claimed to do it, but shy about spending 200.00usd on it!
It's time consuming copying them onto a spreadsheet from viewing them on the TX.
Edit: there are plenty of "Freeware" viewers that turn out to be Shareware, but most are related to viewing 3d graphic files that the mdl format is also used for.
some info found here about ModelConverterX program:
http://gotbush.org/forums/index.php?topic=8126.0
Vini, Vidi, Velcro
Steve M. is offline        Reply With Quote
Old 08-29-2010, 03:24 PM   #69
Oilsands
I am new to the 12FG, but can anyone tell me if the files of models from the other Tx (8, 12, and 14's) work on the 12FG Tx?
Oilsands is offline        Reply With Quote
Old 02-11-2011, 03:58 AM   #70
keijon
Default trex600N+14MZ+spartan ds760
Hello from Finland. I have little problem with my 14mz radio setup. I need .mdl file for it. Somebody have it?
Ty:Keijo Niemistö
keijon is offline        Reply With Quote
Old 04-09-2011, 02:06 PM   #71
qwp777
Default This is good but ...
This is a great item you added for us but can you please provide something like this that has all the .bmp pictures of all the helicopters and airplanes on earth so I can change the picture of my models? I have not be able to find any way to save a picture as .bmp 168 x 80 pixels for use in my radio. Please let me know if you can.
qwp777 is offline        Reply With Quote
Old 04-09-2011, 05:07 PM   #72
aussiemick
Take a photo of your heli.
Open the jpeg in ms paint.
save as a bmp file.
Reduce the size of the image using stretch/skew until the images proportions are correct, check dimensions in windows explorer under the bmp's properties.
Upload to your tx's memory card in the bmp folder.
Assign the photo to the model.
If all else fails post a photo of your heli in jog format and I will convert it for you.
Mick
Mick
Old 03-10-2012, 11:43 AM   #73
Tripledeucer
Default Need Trex 700E F3C setup
Anyone have setup files for Trex 700E, F3C flybar, mode 2, Align 700mx, CC120 ICE HV, CC bec, Fut 401 gyro.
Tripledeucer is offline        Reply With Quote
