| Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
#61 |
Does anyone have a E-flight blade 400 setup for futaba 14MZ I have tryed to do myself is like
Thanx Bob |
#62 |
http://www.14mz.com/downloads/index.html
Plenty of different models available at the above. Just have to choose one and then make adjustments to suit the model your setting up. David |
#63 | |
#64 |
How are these files downloaded and used. I can't figure it out. Maybe I don't have something I need. (Probably enough smarts)
Thanks.....Dave
AMA 6679 IRCHA 675 |
#65 |
Any one have 14MZ Trex 3G setup ?
#66 |
I do, I have it for a 700N, 600N, and a 250.
Mick
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#67 |
Hi there,
I tried to edit my picture files, converting them to bmp and so on but I cant figure out how to make them work on the 14mz?! Any ideas? thanks, G |
#68 |
Does anyone have a way of reading the .mdl files so they can be printed for easy viewing for reference?
I saw one program on the web that claimed to do it, but shy about spending 200.00usd on it! It's time consuming copying them onto a spreadsheet from viewing them on the TX. Edit: there are plenty of "Freeware" viewers that turn out to be Shareware, but most are related to viewing 3d graphic files that the mdl format is also used for. some info found here about ModelConverterX program: http://gotbush.org/forums/index.php?topic=8126.0
Vini, Vidi, Velcro |
#69 |
I am new to the 12FG, but can anyone tell me if the files of models from the other Tx (8, 12, and 14's) work on the 12FG Tx?
#70 |
Hello from Finland. I have little problem with my 14mz radio setup. I need .mdl file for it. Somebody have it?
Ty:Keijo Niemistö |
#71 |
This is a great item you added for us but can you please provide something like this that has all the .bmp pictures of all the helicopters and airplanes on earth so I can change the picture of my models? I have not be able to find any way to save a picture as .bmp 168 x 80 pixels for use in my radio. Please let me know if you can.
Thanks |
#72 | |
Open the jpeg in ms paint. save as a bmp file. Reduce the size of the image using stretch/skew until the images proportions are correct, check dimensions in windows explorer under the bmp's properties. Upload to your tx's memory card in the bmp folder. Assign the photo to the model. If all else fails post a photo of your heli in jog format and I will convert it for you. Mick Mick
#73 |
Anyone have setup files for Trex 700E, F3C flybar, mode 2, Align 700mx, CC120 ICE HV, CC bec, Fut 401 gyro.
