| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#101 |
Awsome, I love my 9303 and am looking forward to learning more about it. I know I havn't even scratched the surface on learning everything this radio can do!! =)
Currently Flying! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123 Retired Helis - Blade CX, Blade CPP, TRex450SE, To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#102 |
Yeah, I'm an addict to Bobs build videos!!!
Mikrokopter building photos and heli x-ray images: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. / Blade mCX / Blade CX extreme / Hurricane 200 / Mini Titan E325 / T-Rex 500 / Logo 500 3D / Trojan T-28 / Super Mini Cub / MPX Blizzard Mikrokopter Cayman 500 / |
#103 |
Hey Bob, dont know if you got your 5245 hitecs yet, but I checked and measured the arms that came with mine. The 2 and 4 arm wheels are too small at 13 and 14mm. The cool blue aluminum arm is 16mm at the second hole. The last hole at the end measures at 19mm. They also include a pretty cool adjustible arm with a locking ratcheted slider. So you have almost infinite adjustibilty with that arm. Hope this helps
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount. T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount. JR X9303. Last edited by bullaculla; 12-15-2007 at 02:55 AM.. |
#104 |
Good Morning Gents,
Thanks for the Vids BOB, what a valuable resource, just a quick question on the JR 9303 segment, you said right near the end that you would REBIND the RX after your set up, why? I thought the bind process was so that the RX ties its self to that particular TX so why do it again or is it just belt and braces, I'm going to get this TX when it gets to the UK so I'm interested in your experience. Thanks again for your time and effort, I have watched most of your builds and the lessons learnt are invaluable. regards Kevin. |
#105 |
You need to rebind after setting everything up so the radio system knows where center and failsafe settings are. Whenever you make major changes to your servos, you should rebind.
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount. T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount. JR X9303. |
#106 |
Team Taco CEO
You want to rebind again so you can get the fail-safe at the right boot-up position. Either at negative pitch or at zero pitch. I prefer to re-bind at zero pitch. If you loose power in a brown-out condition and the receiver resets, the heli can go to zero pitch and float for a while and you may have a better chance of recovering or less damage on the crash.
Edit: ![]() beat me to the punch.
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
#107 |
Thats okay Kev, yours has more infomation
#108 |
Thanks very much for your prompt replies gents, much appreciated, its great to find a forum where there is a wealth of experienced people who will share, so many forums can be real snooty!
Thanks again. regards Kevin. |
#109 |
Two things:
You might want to try the DuBro Heavy Duty arms (standard, not long). They are nice arms, IIRC they have holes at the perfect liengths. Second, other than the BR6000 and AR9000, the only fail safe set on binding, is the throttle position. But you do want your initial servo positions set, which are memorized at binding. Just to be sure people understand how Spektrum fail safe works.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#110 | |
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623 Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560 T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600 T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921 |
#111 |
Team Taco VP
Yes there is a reason to rebind even with the other RX's. As you see we have not set servo reversing or swash settings yet. Thus on power up the servos may jump to a position where they bind up. So after my next segment (coming up this AM) you should rebind again so on power up your servos go to a level 0 swash position and thus dont possibly bind up the servo arms and possibly strip a servo.
In fact just because I like to, after the gyro and tail servo get setup (gain too) even later, rebind again! Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#112 |
I feel like I've bound so much I'm running out of binding.
#113 |
Digital servo questions to Bob and others pros:
If the trex500 requires 16mm to 16.5mm servo arms, and only a few arms provided with the servo will fit this category, will there be an issue with getting the arms 90 degree? Or do we have to use sub-trim extensively to get it 90? Also will the 5245MG, I saw it mentioned the rotation of only 90 degree, will this give enough throws for the swash? Any info on these are greatly appreciated Best regards, David |
#114 |
Team Taco VP
Bottom line it doesn't matter if it is digital or not. If you cant get the servo arm 90 mechanically then you will need to use subtrim! As you can see the provided HS82 servo arms will probably not allow you to get 90 perfect on all 3 servos because there is no way to rotate them and find the best 90 position since they only have one arm. BUT for instance on my 9650's I have a 4 arm wheel and thus can probably find a 90 position.
As for the 5245MG's I dont have mine yet so until I do I cant answer the question yet. Bob
#115 |
Thank you Bob for the info
#116 |
Team Taco VP
Stpe 8 servo setup is up!
Enjoy. Bob
#117 |
You also want to rebind to set the initial output to the gyro so the gyro isn't seeing changes while it initializes.
Someone did a analysis of the steps and came up with 3 bindings, IIRC.
#118 |
Hey Bob, I noticed that while you were putting the frames togeather there were no canopy stand offs, can you put these on after the frames are togeather???
#119 |
#120 | |
I have to admit I have the same thought as Peter, your in the servo reversing menu, why not reverse the 2 going down on up pitch, this must save you messing with the swash menu, 6 of one half a dozen of the other I think, effect is the same, Either way I know more about swash mixing than i did before. Thanks. kevin, |
