Old 07-11-2008, 02:26 AM   #21
HELINHAWAII
Bruce,
Simply awesome man! Any chance you could get that over to MAC?
Jesse
T700N FBL - V-Bar w/ 3DX Head
T250 Super Pro - HS-5084MG Tail Servo
X9303
HELINHAWAII is offline        Reply With Quote
Old 07-12-2008, 01:56 AM   #22
BruceW
Been too busy with work and vacations lately to put the necessary time into the calculator but a Mac version is something I would like to do. Keep meaning to get back to it and hopefully time will be found this summer.
Logo 500 3D /Scorpion HK4020-1100KV (16T)/Jazz80/BLS451/Spartan DS760/BLS251/RT 560mm/AR9000
TRex 450SE
/Scorpion HK-2221-8 (13T)/ AlignESC35(X)/ HS65MG/Spartan DS760/S9650/AR6100
Spektrum DX7
BruceW is offline        Reply With Quote
Old 07-27-2008, 12:52 PM   #23
Wyldman
Awesome job, Bruce! This is making my life much easier.
One suggestion: how about adding an optimum target headspeed for each class of bird. Doesn't have to be exact, but a good rule of thumb to shoot for for each size bird that can then be tweaked to the user's needs/wishes.
Thanks again, man!
Wyldman
AMA 862241
Wyldman is offline        Reply With Quote
Old 10-02-2008, 01:17 AM   #24
BruceW
Thanks again, man!
Thanks Wyldman,
A target head speed for different helicopters would be a great thing to add and hopefully I'll do it some day. For now I just have minor fixes but its on the list now.
For now, here is the latest:
Uploaded version 1.0.9 tonight with new motors added and several bug fixes along with some little features promised a while back. The original link to the file has been updated but from now on I plan on making changes on my personal blog site http://www.brucerc.com or more specifically there is a page dedicated to the head speed calculator at http://www.brucerc.com/software/hscalc/. Of course I'll report back here when there are changes so subscribers can get notified.
You might also notice that I'm looking at creating an easier to use airplane prop calculator. Since I've been flying planes lately I figure that would be the next step. Of course more fixes to the helicopter calculator will come first though.
Thanks for the feedback. An XML import/export/merge feature would make this really nice so all of you could add data and then send it back to put it in a master db. This is a big dream and since it has taken me this long to get back to the tool I'll need to change my productivity rate to make that happen.
TRex 450SE
Spektrum DX7
Old 01-19-2009, 10:40 PM   #25
Ecklund1
Nice utility Bruce! Thanks for the time & work!
Jeff
Jeff
I do not have to be politically correct. I am not a politician.
K-50 / 500ESP /450SEv2 /H200SD / mCX / RF4.5 / 10C 2.4GHz
Ecklund1 is offline        Reply With Quote
Old 01-20-2009, 09:26 PM   #26
akaduck
Any chance of seeing the source code?
akaduck is offline        Reply With Quote
Old 01-20-2009, 10:10 PM   #27
BruceW
How much? The calculation part or the whole thing?
TRex 450SE
Spektrum DX7
Old 02-13-2009, 01:55 AM   #28
BruceW
Added version 1.0.10 of the calculator tonight.
Modifications are:
1. Added motor and gearing for the Trex 250
2. Added gearing for the Mikado Logo 600 mod 1.0 (106T)
3. Corrected the MSH Protos gearing (now 93T)
Can be downloaded here:
http://www.brucerc.com/downloads/HSCalc.zip
with a description of the changes here:
http://www.brucerc.com/software/hscalc/version/
TRex 450SE
Spektrum DX7
Old 05-03-2009, 07:32 PM   #29
NitroAl
Bump!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 08-28-2009, 08:09 AM   #30
Gerald71
What cell voltage I have to use to calculate correct head speed?
My 3s 2.200mAh is at 4.20V after charging and about 3.70V after flying and using about 1.700mAh. So my battery is at nominal voltage at the end of the flight?
The head speed shown is at 100% throttle?
I measured my head speed with a very cheap tool which I'm not sure its working correct. It showed me a head speed of 2.900rpm at 0° with my 3550KV motor 11t pinion at 60% throttle. Comparing to the head speed calculator this is way too high, which shows 2.456rpm at 3.70V with 150t main gear.
My setup: CopterX 450AE V2
Motor: CopterX (CX450-10-06) 430XL Brushless Motor 3550KV & 50A Brushless ESC
Pinion: 11t, 150t main gear
Throttle curve: 0, 25, 42, 51, 60, 65, 70, 75, 80 (reduces many times already)
Gerald71 is offline        Reply With Quote
Old 08-28-2009, 10:29 AM   #31
BruceW
If you have the 430XL, the rated KV is 3700 not 3550. Plugging that in to the calculator gives about 2800 using 94% efficiency (I've found the efficiency factor is usually a little higher than the standard 90). Are you the ESC in governor mode?
TRex 450SE
Spektrum DX7
Old 08-28-2009, 11:22 AM   #32
Gerald71
The CopterX 430XL should be 3550KV (search the internet). But I'm not sure if this is correct.
I'm not using governor mode (not sure if the ESC has one).
I tested my tachometer be measuring flourescent lights. It shows 3.000rpm (50Hz here in Austria). I suppose it should be 1.500rpm because of 2 blades setting? Changed setting to 1 blade and I read 6.000rpm. Maybe my tool is defect?
Old 08-28-2009, 07:55 PM   #33
BruceW
Opps, my bad, I thought it was an Align 430XL.
TRex 450SE
Spektrum DX7
Old 05-08-2010, 09:08 AM   #34
jcinauz
You can do IT! I know you can
jcinauz is offline        Reply With Quote
Old 05-29-2012, 03:33 AM   #35
rcjames
Hey bruce thanks for creating head speed Calculator. I'm using this in Linux. To run it
I used wine. Seem to be working well. Here a picture of proof for those people that are
interested to know if it work in Linux. Yes I'm a big fan of Android os too.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is online now        Reply With Quote
