Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 01-03-2008, 04:37 PM   #1
DavidH
Default Get the real genuine 2.4 update here
http://2.4gigahertz.com:80/downloads/downloads.html
http://www.futaba-rc.com/sellsheets/index.html
Also on the Futaba Flyers Club website.
from the Futaba RC website.
Please note: our software engineers are currently coding additional software which will further optimize the use of your TM-14 module. The completion date is expected to be January 08, 2008. We suggest that you once again update the software at that time to take advantage of the latest optimization.
David
DavidH is offline        Reply With Quote
Old 01-04-2008, 04:17 AM   #2
alex.venom
Thanks, David! ;-)
"Every time Bob's vids are watched, a helifreak is born..."
by rdlohr
Crash Count:
Raptor 50 SE: 02
T-Rex 600CF: 01
T-Rex 450SE V1: 04
and progressing...
alex.venom is offline        Reply With Quote
Old 01-10-2008, 04:28 AM   #3
jonylien
Default 2.4G update
if I use G3 5014 0r 5114 Rx, It nesesaire update?????
Tks ur answer.
jonylien is offline        Reply With Quote
Old 01-10-2008, 08:26 AM   #4
DavidH
The updates are so you could use the 2.4 ghz modules and receivers. You do not need the updates to use 72 mhz or other bands.
David
Old 01-10-2008, 08:32 AM   #5
jonylien
Dear David,
Tks
Jony
Old 01-24-2008, 04:39 PM   #6
OKerbaul
Hi David,
Any news about this optimization? Thanks.
Cheers
Olivier
Olivier
OKerbaul is offline        Reply With Quote
Old 01-24-2008, 04:48 PM   #7
DavidH
Yep, the update is on the websites. dated 1/7/08
David
Old 01-24-2008, 05:16 PM   #8
OKerbaul
Thanks David.
Olivier
Old 05-18-2008, 02:12 AM   #9
R-4-L
is this update affects only the Futaba 2.4Ghz ? or both spektrum and futaba modules?
R-4-L is offline        Reply With Quote
Old 05-27-2008, 01:58 PM   #10
DellGattoGrande
Hello gents!
i got my 14mz 2.4 modul and its looks like i need to have this latest update..
but is there any pdf or text "how to" so i can read it??
what to copy in the card and hot to perform it...
thanx in advance for any info
DellGattoGrande is offline        Reply With Quote
Old 05-27-2008, 02:13 PM   #11
DellGattoGrande
got it
http://www.14mz.com/faq/faq-14mz-q864.html
Old 05-27-2008, 11:32 PM   #12
R-4-L
take off the MODEL folder from the card and backit up somewhere on your pc.
Put the folder UPDATE in the card
Turn the little update switch (beside the card slot on my 12z)
insert the card into the radio and power up
the update should commence
when completed, take off the card and delete the update folder, put back your MODEL folder and turn the switch back to normal position.
Be sure your battery is charged though.
PS. This is all according to my 12z instructioons, but 14mz should be no different.
Old 05-27-2008, 11:33 PM   #13
R-4-L
oh u found it, ok good luck
Old 10-07-2008, 07:13 AM   #14
bdmcobra
I have been having problems with my sprectrum module in my 14mz. The elevator and rudder servos are getting mixed somehow. put the pcm back in and everything is fine. Could this update help with this?
Fly once a day to keep the insanity away.
bdmcobra is offline        Reply With Quote
Old 10-07-2008, 09:03 AM   #15
DavidH
No the update will not correct any problems that are being seen when using a Spektrum brand 2.4ghz module in a Futaba 14MZ.
The update is for using Futaba 2.4 ghz module and receivers with the 14MZ.
David
Old 05-01-2010, 08:51 PM   #16
321
So what is the latest software update for the 12Z? Mine hasn't been updated since it was converted to 2.4, a long time ago already. I guess if I had a 14MZ then I could go to the Flyers Club site and find out for myself, LOL.
Some of the best replies are the ones that are never posted.
Shopping for the lowest price is a complete waste of flying time.
321 is offline        Reply With Quote
Old 06-29-2011, 07:59 AM   #17
naif_r/c
thanks very much....
I try 2 days..asked all friends and check all most website..but nothing..
but from you only 5 minutes..
I update my remote..
thanks..
naif_r/c is offline        Reply With Quote
