| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
Team Taco VP
OK I got asked to do a overview of what BEC is vs a regulator and what a BEC is and how it gets hooked up.
So I whipped this up real quick. BEC 101 - What's a BEC and how do you hook it up (47 Megs) Enjoy Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by Finless; 01-03-2008 at 07:09 PM.. |
I am ACTUALLY going to watch this one cuz I need to get my learn on.
Dan Da Dawg - JR X9303 Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV |
Very good video Bob. Not just for noobs! Good tip about using the gyro signal plug for suppling power.
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount. T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount. JR X9303. |
I've never used a BEC but I'm thinking of putting in a Park BEC for my Trex. But on an ar6100 their is a BAT slot on the reciever used for binding. Can't we just plug in the BEC through that line? Or do we still have to remove the positive lead from the Align speed control?
Thanks guys.
Peisen "flying rc helis is like fighting every law in the book of physics" AMA #902366 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. << Checkout my YT |
Team Taco VP
You MUST still remove the positive lead from the align ESC or you will have 2 power source inputing and casuing a problem. Remember tjhe buss bars! They connect to every connector.
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
What if you want to run two BECs in parallel? My JR R921 has a batt A and batt B. can I just plug a BEC into each of them?
#7 |
???? Thought the Align ESC had none BEC built into the unit ? Are you saying it supplys some kind of power to the RX which may conflict if lets say putting in a CC BEC instead of the Align BEC and 2S Lipo ?
T-Rex 650 CF / Scorpion 4025-630, 12S To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Jive 80+HV,2 x TP 3300 6S V2, Radix 710SB,Super Stubz,Futaba 9451,Spartan DS760/BLS251.Quick UK swash and tail T-Rex 700N, OS 91HZ, Hatori 939, Radix 710SB, BLS 451, 9254 for throttle, Spartan DS760/BLS251, Quick UK tail, |
#8 | |
Which also means, if you use them with an ESC that has no internal power (Gaui 50A for one),. you cannot plug the ESC into the Park/SportBEC as it will get no power.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#9 | |
Team Taco VP
Bob
#10 |
Team Taco CEO
He's just saying that some BEC has an input for your ESC and it disconnects the red wire for you and feed the control signal through... Personally I like to plug my ESC direct to the Rx so it's more reliable.
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
#11 |
Team Taco VP
Ah OK... I forgot about that type.... Heck I have one of those too and could have added it in the video.
Bob
#12 | |
Maybe a dumb question, but can you explain this a little as i was believing that the Align ESC had none BEC and as such do not give any power to the RX other than the throttle signals as it is supposed to do.
#13 |
Team Taco VP
The Align ESC for the 450 has a BEC. The Align ESC for the 500 has a BEC. The Align 75 and 100 for the Trex600 does NOT have a BEC.
Bob
#14 |
Team Taco CEO
Bob was refuring to Align ESC for the 450 which as a BEC onboard. Align ESC for the 600 don't have an onboard BEC.
Edit: damit... faster than me@#!! ![]()
#15 |
Ahh...... I am quite narrow minded since i only have to deal with my 600 and you have to think off a whole bunch of different setups. Lol.
Thanks.
#16 |
Great video. Thanks Bob.
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh 600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19 |
#17 |
So if you hook them up to a SportBEC the "normal way", inline, they don't get power. So you have to hook them up like other BECs, with both the BEC and ESC connected to the Rx.
#18 |
Team Taco VP
How can the BEC not get power if it is hooked to the battery? You shouldnt be powering the Sport BEC from the ESC's BEC or that doesnt buy you anything. The BEC has a set of battery wires that get hooked ot the main battery.
Bob
#19 |
He's referring to the ESC (without internal BEC) getting power from the receiver for the control circuitry.
#20 |
Team Taco VP
Huh? The ESC doesnt need power other than from the main pack BEC or no BEC. The only thing the ESC needs from the RX is a throttle signal.
A real BEC (not a regulator) gets it's power from the main battery and converts it to 6V or 5V to power the RX. Bob
