Old 02-03-2011, 12:49 PM   #141
BeerInn
Ahaaaa. That I (obviously) did not know, I just assumed they were from the ESC.
Thanks again!
edit: I'm such a dope! ...You specifically say that the sound is from the motor about 1 minute into your ESC tutorial video ...I guess that's what happens when I'm sleep deprived. Sorry for an 'already covered' question.
BeerInn is offline        Reply With Quote
Old 03-03-2011, 06:42 AM   #142
chiropractor
Very Well Explained. Clear and concise. TY
chiropractor is offline        Reply With Quote
Old 10-17-2011, 11:22 AM   #143
Veritable Plethora
Originally Posted by Finless View Post
You MUST still remove the positive lead from the align ESC or you will have 2 power source inputing and casuing a problem. Remember tjhe buss bars! They connect to every connector.
Bob
THANKYOU!!!!
Veritable Plethora is offline        Reply With Quote
Old 12-12-2011, 02:49 PM   #144
doug100856
Ooops, wrong topic !
X50 Titan/DX8 nitro daily driver
HeliArtist AH-1W
Mikado Logo 550SX en route
JR Vibe 500E electric daily driver
doug100856 is offline        Reply With Quote
Old 08-26-2012, 10:34 PM   #145
dkb194
Default Battery
Can anyone tell me what battery I should get to use for my 450 setup instead of using my LIPO and ESC's BEC.
dkb194 is offline        Reply With Quote
Old 08-26-2012, 11:06 PM   #146
mejmea
I use one of the following methods:
1) Use the flight battery and the ESC's BEC. Of course you want to use caution and make sure your throttle hold is on, temporarily change your throttle curves to 0s across the board, and/or disengage your motor pinion from the main gear.
2) Use a spare external BEC. You can make up a connector to feed it from the balance or main leads of your flight pack and then you don't have to worry about anything spooling up at all since the ESC isn't even powered.
If you want to power your receiver directly from a separate battery then determine what the max voltage input the your electronics can tolerate is and choose an appropriate battery source. You'd also have to make up a connector to connect the battery to your receiver. For my 450 I run the BEC at 6 volts so if I were to use a separate battery I would choose something that would provide 5-6 volts for setup. It seems easier to simply use one of the other two methods to me...??
Always learning, and enjoying the process!
mCP X,Trex 450 Pro, Rotormast V-22 Osprey, Blade mQX, Helimax 1SQ
Planks - Super Cub w/floats, PZ T-28, PZ UM Cub, UM P-51, PZ P-47 w/ retracts and flaps, GP PBY Catalina, HL F9F Panther EDF
mejmea is offline        Reply With Quote
Old 10-08-2012, 08:17 AM   #147
69maverick
Default magnet?
Bob I noticed in the video that you still had the round magnets on the wires. Do you really think they are necessary with Spektrum radios? I haven't used them in years with no issues..
69maverick is offline        Reply With Quote
Old 10-09-2012, 02:10 AM   #148
pinguin
That is not a round magnet, it's a ferrit ring. It has effect on the FM (35, 72, 75Mhz) radio, to reduce interference.
But on 2.4Ghz radio, you can remove it.
pinguin is offline        Reply With Quote
Old 10-09-2012, 08:52 PM   #149
69maverick
thanks,That is what I thought. I don't know why I thought it was a magnet? but now that you say it ! just know it don't do anything from what I can tell with a Spektrum or any 2.4 radio.
Old 11-28-2012, 11:25 AM   #150
xioxia
Allways use ferrit ring!! Allways
Dont even ask why..
xioxia is online now        Reply With Quote
Old 05-16-2013, 06:10 AM   #151
47box
Hi,
I´m mounting a Trex550E DFC and the ESC came without a BEC....I will need do the setup like showed on video.
Which one BEC has best efficiency (less warm)?
Tks.
47box is offline        Reply With Quote
