Old 04-14-2012, 01:58 PM   #281
nmdesertracer
My tail boom cant move forward I got a extra plastic servo mount against the tail block. Thats the first thing you should do to your heli.
Juan Martinez for President!
nmdesertracer is offline        Reply With Quote
Old 04-22-2012, 11:11 PM   #282
Wolfpackin
Originally Posted by bchrny View Post
Imagine this- you are flying and your tail boom loosens up in mid flight, slides forward thus loosening the belt: with the pulley in place the belt is forced to make contact with the rotor pulley. Without the IDLER pulley in place-well you get the picture. Your call, your machine, your money. They make more silicone! Should I remove my blinker switch in my car- Nobody uses them anymore. Do they???
If that happened the belt could just slip on the front tail drive pulley.
The idler pulley is known to cause issues, crashes, and many have eliminated the problem by removing it with no ill effects.
Others have no problem with the pulley on the heli.
So yes, always up to the user.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is online now        Reply With Quote
Old 04-25-2012, 03:02 PM   #283
bchrny
Again I will ask the question, WHAT ISSUES? Everyone keeps saying it causes problems, so what are they? I have mine on and I don't notice problems. Discoloration of the back side of the belt thats not a problem (cosmetics). Thats the only thing I have seen mentioned, Yeah I've seen the posts about the silicone to stop static but that is an assumption, to release a static discharge into something the thing has to be grounded- did you ever experience a lightning strike to an aircraft? It does nothing without being grounded. So in essence I would really like someone to explain what these 'so called' problems actually are? Thanks for your input! Any knowledge would be helpful. Thanks again.
bchrny is offline        Reply With Quote
Old 04-25-2012, 10:28 PM   #284
Wolfpackin
Back in the day SE V2 owners were experiencing belt problems like it coming off the pulley/gear, not riding true and getting stuck between the pulley and shaft or side plate of the tail case. Most times this type of failure caused crashes due to loss of tail control.
It's been years since I read this whole thread but some of those issues are discussed here. There are also multiple other threads regarding belts getting stuck, jammed or broken due to the idler pulley system. Read this whole thread and try a search, there should be lots to read.
But for those that did have problems like belt jams or jumping on the SE V2, removing the idler pulley solved them.
As I stated, not all owners of the SE V2 had catastrophic belt failures or chronic issues. But for those who did, removing the idler pulley made that stop.
Note that Align no longer has that pulley on most of the newer designs...it's just not needed and does more harm than good.
Using silicone on the belt does not discharge a static charge it prevents the system from generating static electricity, generating a charge, in the first place.
Silicone on the belt also helps condition the rubber compound helping it break in, makes it more supple and improves longevity.
I do this on all of my belts and have several that lasted over 500 flights before being replaced. The belt on my 450 has almost 550 flights and it still looks fine.
I've also never had any static issues and I live in a very low humidity environment pefect for static charge buildup.
Old 04-25-2012, 11:14 PM   #285
bchrny
Default The first I've heard
Thanks for that info, I did try to find the problems as stated but like you said "there are many posts" too many to sort through them all. As many posts as I did search, I could'nt nail down any one particular that refered to above said problem. So could that be the cause of my occasional slight twitch which does'nt happen to often? I suppose the only way to find out would be to take it off and test it. Should I remove the screw also?
E-Flite Blade mCX x2, E-Flite Blade CP PRO, Align T-Rex 450 SE V2 w/ Hi-Tec HS 65HB cyclic servos, JR DS 3500G tail servo, E-Flite RG 90HL gyro, Align RCE-BL35X esc, Align 430X 3550 KV brushless, Spektrum DX6i DSM2 TX, Spektrum AR6200 RX
Old 04-26-2012, 02:18 AM   #286
bchrny
: banana
Old 04-26-2012, 09:15 PM   #287
Wolfpackin
If you don't see any belt damage like fraying or scuffing then it's probably not related to the idler pulley.
BUT, it could be static discharge.
Some people put the bolt back in to clean up the look, no holes in the side plate.
Just another quick question: My girl and I have been discussing a very similar issue, she as it seems has a couple of friends that are about the same age and ran into problems at the recycling plant in which they work. At times the reek of the refuse just gets to be intolerable, they need their jobs and replacing jobs these days really isn't a viable option. So the question is, should they just have their olefactory glands removed??? RLMAO:bana na
That's up to them...maybe a little Vicks under the nose to mask the smell.
Any other life questions I can help with?
Old 04-27-2012, 01:56 PM   #288
maraispc
Ok - to give some further credit to the problem that Wolf described above...
When I built my SEV2 a few years ago there were quite a few posts of folks who had the belt coming off the rear toothed pulley and jamming in between the side plate of the tail unit and the toothed pulley. In many cases this resulted in crashes.
Anyway, so while I completed the build I kept the "idler" pulley in place as per the manual, guided also by many counter-posts of folks who never encountered any problems and arguments that the manufacturer must know what they are doing (also if I removed the pulley then the tail unit will look so "incomplete"!!)
Ok, all went well...for 15 or so flights and then it happened...belt ran off the toothed pulley and partially jammed in between the toothed pulley and side plate. At that stage I was still at the hover stage - heli about 2m up - this caused a sudden & dramatic power loss, but other than a hard landing - no other damage. I this had occured during FF it would have been a crash for sure.
New belt, removed the "idler" pulley and no more problems with hundreds of flights lightly lubricating the belt with silicon spray every 15 flights or so. Removing the "idler" pulley was an easier decision at this stage as the 450 Sport was released and the tail unit did not include this.
If you do decide to keep the "idler pulley", keep an eye out for belt edges fraying and ensure the"idler" pulley & belt is lubricated (silicone). Contributary factors that I identified when the belt jammed were slightly frayed belt edges and dry belt & pulley.
maraispc is online now        Reply With Quote
Old 04-27-2012, 02:13 PM   #289
Wolfpackin
I appreciate your first hand account of the idler pulley problem.
Thank you kind sir.
Old 04-27-2012, 03:39 PM   #290
maraispc
Old 04-27-2012, 08:08 PM   #291
bchrny
That goes double, thanks for the responses I'll go ahead and remove it. Better to voluntarily lose a part than pay for others for a grave error! Thanks a heap! Or more like one less heap
Old 05-18-2012, 08:42 PM   #292
n1977m
I haven't tried to run mine without the idler (pressing pulley). I installed another tail unit that was designed without the idler. Problem solved. I did notice that the tail unit with the idler has a base where the screws pass all the way through to the other side requiring the belt passes to run closer together. The unit designed without the idler has a base where the screws thread into the base and do not pass all the way through thereby allowing the belt passes to run farther apart.
n1977m is offline        Reply With Quote
Old 05-22-2012, 12:26 AM   #293
TomRex
Also the old Rex's used a first version tail shaft with a pressed on plastic cog pulley so belt slippage was reduced with more contact on the pulley. Just so all concerned will know the idler pulley is really called a snubber pulley in the mechanical world.
old school by todays standards but probably works better than the new stuff now.
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 05-22-2012, 12:53 AM   #294
Wolfpackin
That picture should be in the HF Hall of Fame.
It's been posted more than most and shows the pulley removed, fuel tube mod and chinese weight mod at the same time.
Classic old school stuff for sure.
