#261 | |
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256 Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257 |
#262 |
i've had about 20 flights on the Venom 3200. Solid head speed. Steady under load. I use them as a 6 min warm up pack before i put in the 6s 2650 45c TP pro power packs.
#263 |
hai all.. i have question about setting my t500
aim using moto hyperion 1600kv ,hobbywing 80a esc, 2600 mah 35c, 13pinion. its ok this setting using 80a esc coz my cell like hot than using stock esc 60a. |
#264 |
Motor Scorpion
hk-4025-1390 or 4020-1390 hk-4025-1100 or 4020-1100 hk-4025-890 or 4020-910 Flerpie did give me a data sheet for them but I still don't see volt input. Is way to get the info by some formula ???? I know they were trying to help but I need to understand what there doing to get volt input. based of the data sheet from scorpion. Well with the help of flerpie I did get a sheet with factory recommendations. Scorpion listed the 4020-910 as a 8s to 10s motor. So with that said I have some play room with it. This is what I'm going with ..... Castle Creations Ice2 80HV Castle Creations BEC-Pro ( high input volts ) Scorpion 4020-910-5mm Battery 9s 3-3s 2200 Mah (13T,14T,15T) for head speed tuning (Total battery weight 559g) 8s 2-4s 2650mah (15T,16T,17T) for head speed tuning (Total battery weight 582g) I will have 5 pinions to do some testing with. I think this is a good starting point.
Tarot 500/550 9s / Tarot 450ProV2 4s / 600E V1 8s Academy Of Model Aeronautics 98418 If Align put their name on a pile of dog crap stuck 2 blades in it and packaged it in a super combo, people would get in line to pre order. I just dont get it Last edited by MrHeliNewbie; 11-28-2011 at 10:27 AM.. |
#265 | |
instead of just the S rating. I think that's because some folks run Lith-ion batteries which have a different per cell voltage. It's a small difference like a volt...so it's no big deal. It's just easier for the motor people to cover both cell types if they just call it by S rating. Doin' the math is the only way I know of to come up with how many volts 10S would equal.
HK Best Of Custom 450s & 500 Build Different! |
#266 |
Hi, can someone tell me if Venom is a good brand for a charger? I'm new to the hobby and I just purchased this charger below before consulting the knowledge of this forum.
I also bought a Venom 3s 11.1v 5000mah 35c BTW, this is for my new TREX 450 3gx which I have yet to open https://www.gonitrohobbies.com/Produ...tCode=VEN-0657 Thanks for the help...
MCPX v2 - Trex 450 v2 - Trex 550e v2 - DX8 |
#267 |
I had a Venom Pro It did a good job. The chargers did have problems with the build in fans about a year ago. Don't know if there still having problems with them or not.
Mine started making noise after about 6 weekends of racing indoors last winter. I now use a Hi-Tec 4 battery combo charger. You have to get an inverter to run this unit indoors. Nice being able to charge 4 batterys at once. But this charger lowers the charge amps down to 5amp max when charging 4 batterys. Max amp output is 20 amps so you get a 5 amp charge per battery.
Tarot 500/550 9s / Tarot 450ProV2 4s / 600E V1 8s Academy Of Model Aeronautics 98418 If Align put their name on a pile of dog crap stuck 2 blades in it and packaged it in a super combo, people would get in line to pre order. I just dont get it |
#268 |
Thanks MrHeli. I guess I'll give it a try and see how far I get with it. As I get more advanced, I'll explore better options
#269 |
3S 5000mAh is far too big for the 450... It won't fit under the canopy and will make the bird too heavy. You should get some 3S 2100mAh instead, even 2600mAh might be pushing it...
Good news, the adapted batteries for the 450 are cheaper than the one you bought.
Blade mCPx | T-Rex 450 Pro 3GX (setup) | Logo 400SE V-Bar (setup) | Aeolus 50 / OS55HZ / BeastX (in build) |
#270 |
Good info here. Looking to get a 500 and xactly what I was looking for
#271 |
hey guys. im going 8s on my trex500. I want to run the 1210 with a 13t pinion. I have read where guys say this is a good set up with lots of power. My concern is that scorpion lists this motor as a 6s motor. Do you guys think it will be ok to run 8s on this???
-trex700n -trex600n -trex500 -trex450 -trex250 ...blade mcx...best cat toy so far. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ...& Aurora9 |
#272 |
I have a quick question as well! I have a t-rex 500 i am gonna set up for running on 6 cell battery!
Batteries i will be using are pulse ultra 6s 3000mah 45c. Electric motor i have is the align 500mx. I have a gaui 100amp esc but will be selling it to buy a castle creations esc! Im thinking i will go with the 100a esc so that i have governor mode! What is the best size gear to use on the motor?? And what head speed should i be aiming for to make this heli a 3d monster?? Also this is the 500 esp converted to DFC! All tips are greatly appreciated! thxs Keith |
#273 |
13T pinion should be fine for 2600rpm head speed
DX8 mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades AMA#948801 |
#274 |
i had the older 1600kv motor and 13t pinion. was flying around 3000hs i believe. it flew pretty good. i know there are alot better setups for 6s though. ive just flown that stock setup though the last 5 years. ive beat the crap out of that align motor and esc. the castle 100 should be more than enough. anyone know about the scorpion 1210 on 8s though?
