Old 10-29-2013, 05:37 PM   #1
leokat001
Default 300x tail servo not centering???
Hi all,
I just got a 300x with a dx6i both new. I have completed the radio setup and the binding process 9have not tried to fly yet). My question is about the tail servo not going to center when I let go of the yaw stick is this normal?
Thank you
leokat001 is offline        Reply With Quote
Old 10-29-2013, 07:02 PM   #2
KiloXray
Originally Posted by leokat001 View Post
Hi all,
Thank you
Totally normal. Go maiden that bird!
Protos Max v2 --- Gaui R5 --- OG Oxy 3+ --- TE Oxy 3+ --- Jeti DS14
MSH USA Flight Team --- Brain Test Flight Team
OG Oxy Heli Rep --- Lynx Team Pilot --- Citizen 268
KiloXray is online now        Reply With Quote
Old 10-29-2013, 07:59 PM   #3
leokat001
Thank you that is really good to know... So is it the gyro telling me that it is the one in control (; ?
Old 10-29-2013, 11:10 PM   #4
floreos
Noooo use simulator first!!! save money!
floreos is offline        Reply With Quote
Old 10-30-2013, 05:22 AM   #5
sn00p
Totally normal because your in heading hold not rate mode....
If you wanted to check you can simply turn the gyro gain to 50 (below 50 on the DX6i switch the HH off). Your servo will then act like any other servo on the heli and return to centre.... this is how you would set the servo horn and rod length when setting up
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote
