Old 11-19-2013, 08:29 PM   #1
flyingquisinart
Default Radio system on/off switch for nitro
Hi,
I have a nitro heli that's a few years old, with Fromeco AZ regulator and 2 cell LiFe battery.
The regulator was from the days before HV servos etc,
Anyway, my servos are rated to 6V nominally and I now have retired my old 4.8V 9254 tail servo and have HV one on. I never removed the regulator even though I could have, because it has a pin flag switch and I was too lazy to change things out.
My pin flag switch is the kind that I just zip tied to the frame. Well, it's failing, so now is the time to redo stuff. My plan is to remove the Arizona regular because I don't think I'll need it now.
What switch, if any are you using between the battery (in my case a LiFe batter with dean connectors AND servo type connectors) and the receiver? I liked having the pin flag switch on the frame because I could turn it off quickly in case of a crash--i.e to avoid servo bind/stall due to damage. Is there a reasonable cost switch that I can use? I don't want to custom mount anything--to much work, LOL, just keeping it simple. The stock frame placement for a regular old-fashioned switch is inaccessible under the canopy so that's out.
Thanks for suggestions!
Matt
Pantera P5 50 RNFBL, Blade 130X, mcpx, Gaui X5 FES
flyingquisinart is offline        Reply With Quote
Old 11-19-2013, 09:54 PM   #2
whoodie
I'm running 2s Lipo, unregulated with 4 JR8915HV and 1 Futaba BLS256HV servos through a Fromeco Badger. I chose the single Deans in and 2 JR out option. I haven't had an issue with it. You will have to drill 2 holes to mount the switch on your frames, and I also had to make some taller standoffs to keep the back of the switch PCB from shorting out against the frame, your install might differ a bit though.
http://www.fromeco.org/Products/04FRCBADSW-420s/
whoodie is offline        Reply With Quote
Old 11-19-2013, 10:52 PM   #3
Nitro Bird
I don't use a switch on my T-Rex 600 or 700 nitros. I just plug and unplug the battery using TC3 connectors. That way there is no switch that can fail and cause a crash.
Nitro Bird is online now        Reply With Quote
Old 11-19-2013, 11:22 PM   #4
Raptor 50
Have a look at perfect regulators.com they'll have a soft switch for you . You can use a bind plug with a flag on it to turn on or there is also a micro switch built in . Its half the size of a match box and if anything fails it stays on . Can use 2s lipo for HV servos or use your life battery no problems.
Raptor 50 is offline        Reply With Quote
Old 11-20-2013, 07:33 AM   #5
jharkin
Im trying out an EC3 arm plug on my new build, but for a good inexpensive switch I like the HD JR's. The Chargeswitch is nice because all three leads are wired to the charging plug so you can rig it as a balancing charge port for LiFe.
http://www.horizonhobby.com/products...switch-JRPA004
http://www.horizonhobby.com/products...s-gold-JRPA001
-Jeremy | AMA L7278
Whiplash-Gas, Helix G700, T-Rex 450 FBL conversion
A bunch of elec, glow & gas airplanes
, Futaba 14SG
jharkin is online now        Reply With Quote
Old 11-20-2013, 08:20 AM   #6
dchekas
This is what I use. Very high quality switch that has some nice design considerations for our RC vehicles.
It takes some work to mount, but I've been very pleased with mine.
dchekas is online now        Reply With Quote
Old 11-20-2013, 08:38 AM   #7
JesusFreak
I'm using one of these now.
http://www.horizonhobby.com/products...-plug-JRP04507
"Keep it pithy."
eAurora, TREX600E, TREX 600 HFEX, TREX500, Vibe 50
(Professional grade pretzel maker).
JesusFreak is online now        Reply With Quote
Old 11-20-2013, 03:08 PM   #8
Sowa
I as well am not using a switch. I just see it as an extra failure mode that is unnecessary, I use ec3 plugs. Pretty simple plug the battery in, put the canopy on and fly. No worries.
Protos 380 - Xnova 2820 - HW60V4 -Brain2
Goblin 570 - 91SRX Tareq - Hatori - Brain
Goblin 700c - TRM VX300se - TRM - Brain2
Protos 770 Max V2 - Xnova 4535 - HW160V4 - Brain2
Sowa is online now        Reply With Quote
Old 11-20-2013, 05:37 PM   #9
flyingquisinart
For those that just plug them in, do you just have an adaptor from the EC3 to two servo wires in parallel that go into the receiver/FBL unit?
My LiFe battery has a Deans connector on it now, so I'd use that rather than re-solder that end.
Matt
Old 11-24-2013, 04:47 PM   #10
flyingquisinart
Default Re: Radio system on/off switch for nitro
Thanks for the input guys! I went with Deans to two servo type leads and just plug it in directly. I'm using aux3 and the bind/data channels both for power. Simple, now I have just the battery and governor on my radio tray.
Matt
Matt
