Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...) > DJI Multirotor Forum(A2/WKM)
DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM)
Old 12-12-2013, 09:28 AM   #1
jamesb72
Default Naza V2 Phantom replacing std receiver with OrangeRX R800X receiver
I used an AR8000 in first phantom to replace the v1.1.1 FASST receiver, have picked up a 2nd phantom, and wanted to try the OrangeRX R800X which looks like it will fit fine, and I like the long aerials (easier then mounting a sat receiver on leg).
It has an SBUS output, anyone using this with the Naza X2 (sbus) input to save running 6 servo leads between receiver and Naza ??
I am guessing you need to bind first then setup radio/failsafe positions, then rebind to set these in receiver ?
jamesb72 is offline        Reply With Quote
Old 12-12-2013, 10:19 AM   #2
Empire Support 3
If they haven't fix the channel mapping for sbus on Spektrum then it really wont work. There will be some channel mapping issues.
If I remember correctly throttle and elev will be mapped incorrectly.
Empire Support 3 is offline        Reply With Quote
Old 12-12-2013, 11:48 AM   #3
setishock
Registered User
But ES3 if I was to take the receiver out of the Phantom and put it on the naza m lite on my F450 it would work with the stock Phantom transmitter?
setishock is offline        Reply With Quote
Old 12-12-2013, 05:45 PM   #4
Empire Support 3
Correct.
Old 12-13-2013, 03:55 PM   #5
jamesb72
Originally Posted by Empire Support 3 View Post
If they haven't fix the channel mapping for sbus on Spektrum then it really wont work. There will be some channel mapping issues. If I remember correctly throttle and elev will be mapped incorrectly.
They haven't and you remember correctly !!
Aileron is unmapped, and elevator maps to throttle, so Sbus with R800X is a non starter.
I connected up using traditional male to male servo leads (six connections) which works fine.
I use a heli model on DX8, U to ch6 and use pitch curves to select flight modes and throttle hold pitch for failsafe, gyro menu for IOC on ch5/X2 and ch8/knob for x1 so I can adjust gains in flight if needed.
The R800X is thinner but longer than the AR8000 so fits inside the case fine, and I ran both aerials down through one hole, one is taped along arm, the other taped into skid leg, so they are 90degree's apart, should give similar/identical range to the AR8000 without having to mount sat receiver on leg which looks untidy.
I made a video showing this under 4 minutes
