| X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information |
I have an the ...35G ESC installed in my MX400 and went through the setup with the Tx as per the instructions.
When I raise the throttle slowly, the motor jerks only a couple teeth on the main gear, making the blades turn a bit each time I try to start up. Finally, after about 3 or 4 trys, the soft start engages and the hs climbs up. Once it starts, it's working and flying great. Any ideas on the sporadic inputs to the motor and then after a while it starts up? Could it be the Low Throttle Response setting on 35G? Thanks. (using MX400, 35G esc, 3s/11.1/2100's, stock Helimax 2580kv motor, epa's 100% around, Futaba T6EX 2.4 Tx-Rx set, with esc settings: Brake Disabled, mid-timing, low batt-protection, Heli-1 mode, throttle response Low) |
I had that happen. Check the connectors and make sure they are not loose. It might be timing or a break in the coils.
Team Outrage OPM - Fly it like it aint yours! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. JR X9303 2.4 Baby. I have felt the difference and I like it! Don"t make me list 'm all ! |
Matt i having some what the same problem. I have a t-rex 450xl. when i start up my heli, it run for 30sec and then starts to buck, then it shut down then start up again by itself. it keep doing that at 1/4 thro position. It get hot quick. when i could pick it off the ground time i pick it up to hover it comes back down. now it start bucking again. Anybody knows what could be the problem? The connectors are fine. How do you check the timing? Thank you.
Dear Matt I had also that problems take care if it gets too hot the bec in the ESC wont work anymore. Then you have failsafe on your helicopter which is not really nice. My dealer exchanged the ESC for free. But anyway I installed a sperate BEC which is the little money really worth. One safed crash is enough.
Jan |
