Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 01-16-2014, 11:21 AM   #1
ukiah74
Default How can you get instructions on how to use 3GX governor?
Hello I am trying to get the governor function on the 3GX to work correctly but I know nothing about how to to set it up, what the perameters in the controller should be and how it effects the heli..
This is the last thing I have to figure out, to be done with set up and finally get to do some real flying..
For now I have the setiings is my tx (DX8) set to 80%, for idle up 1 & 2, 0 on normal setting. My heli (trex 700N Pro DFC, ys91sr,3GX).. I'm still breaking the motor in and tuning, and when I do a punch out to check the midrange, She sluggishly climes then as the heli gets moving up the motor revs really high? my throttle curve is 85,83,80,83,85 in IDLE UP 1-2.. I believe my headspeed is suppossed to be around 2,000 rpm, but at hover,or full throttle? and how do you find out what your rpms are?
"Please", some one has to know how to set this booger up.. I can only cruise around in normal mode... NO Fun Please any help would be great or maybe a phone number to someone whome works for align and speeks english so I can get some instruction on there products.. Thanks Guys.... Off to work
ukiah74 is offline        Reply With Quote
Old 01-20-2014, 11:16 PM   #2
ukiah74
ok so i figured it out.. I havent been in the 3GX program for awhile and forgot about the step by step it gives you.. No wonder I didn't get any replies.. lol.. Anyways I had played with the chart at the end of the program in the past with my 550E, but i didnt have it plugged into the pc at the time so it didnt do anything, this time it did, but a new issue has risin.. it will not allow me to go over 14,950 on the engine rpm wich gives me a head speed of only 1,823 rpm's.. I would like to get up to around 2,000rpm, since I have a usable range of up 17,000rpms on my YS91SR..
Old 01-21-2014, 10:39 AM   #3
nameci
I have posted the link for 3GX governor set up information for another thread you created. You have multiple thread started on this subject.
http://www.helifreak.com/showthread.php?t=595020
nameci is offline        Reply With Quote
