Go Back   HeliFreak > R/C Helicopter Support > 100 Class Electric Helicopters
100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-29-2014, 11:37 PM   #1
Danny TERRA
Default Trex 150 Head Speed Problems
My head speed is not getting up as high as it should be. I have tried everything. Before you ask, the first thing I did was set throttle end points. I even bound a friends helicopter to my controller and there's was perfectly fine. I bound mine to their controller and still the problems. I am pulling my hair out about this one. I have had nothing but problems since getting this helicopter. What should 100% flat curve head speed be? Please help!
Herbie T
Danny TERRA is offline        Reply With Quote
Old 01-29-2014, 11:47 PM   #2
Dylwad
Default Re: Trex 150 Head Speed Problems
Should be around 7000 rpm
Have you tried increasing throttle channel travel adjust, just in case?
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote
Old 01-29-2014, 11:58 PM   #3
Danny TERRA
No I haven't. I am using a JR controller. I will try that now. Should I try it at full 150%?
Herbie T
Old 01-30-2014, 12:04 AM   #4
Danny TERRA
I tried it with no success. I have a phone tach which isn't all that accurate, but it's stating about 4900rpm.
Herbie T
Old 01-30-2014, 03:47 AM   #5
Thermikflieger007
Set your Battery Type to "Auto" ! When you do on "2S" it will have less power...i think this is a failure in software
Thermikflieger007 is offline        Reply With Quote
Old 01-30-2014, 05:53 PM   #6
gabeoravitz
Holy cow. I knew this thing was screaming, but I didn't realize it was 7000rpms! Did you tach this yourself?
gabeoravitz is online now        Reply With Quote
Old 01-30-2014, 07:34 PM   #7
Dylwad
http://www.helifreak.com/showpost.ph...postcount=2546 confirmed with a tach, 7100 RPM, V1, HP06V2 8200KV 10 tooth
I have had an MCPx up towards 8000RPM
Old 01-31-2014, 06:59 AM   #8
Danny TERRA
Default Headspeed problems
Thanks THERMifleger 007 you nailed it.Had it on 2 cell lipo and power was way down.Switched to auto like you suggested and it is great now.THANKS.
Herbie T
Old 02-03-2014, 12:37 AM   #9
gabeoravitz
haha i couldn't imagine trying to fly an MCPx at that head speed. That would have to be perfectly, perfectly balanced.
Old 02-03-2014, 12:49 AM   #10
Dylwad
It gets to the point that moving a 3 mm square piece of tape 3mm on the blade makes a difference lol.
Old 02-03-2014, 01:51 AM   #11
gabeoravitz
And considering how the mcpx 3-in-1 has almost zero tolerance for vibes at higher headspeeds...yikes!
