Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters > TRM Power
TRM Power TRM Power - Toxic Al Factory Support Forum Worldwide. Any Product.
Old 06-17-2005, 12:06 PM   #1
bigrcr
Default NEW! TRM Tuned Pipe
Here are a few preliminary shots of the PROTOTYPE Toxic Racing tuned pipe system. I am currently pulling down the Spectra-G for installation on the TRM-231. For now the motor has to be mounted with the head facing forward due to the length of the pipe and the fact that the prototype system is currently one piece. This has been done for initial test purposes only!!!
The production model of the pipe system WILL be designed as two piece and the header will be designed to run on either side. This means that the motor can be run either forward facing or backward facing. As I said, this is only a working prototype and has been set up as it has for ease of handling.
I will post mounted pictures and let everyone know of the progress as the unit is tested. The pipe should easily be a gain of power by 30% over stock exhaust systems.
The motor shown in the pictures show the adapter. This motor is the new TRM G-26 proto for testing. It will not be installed with this pipe, yet. The pipe is being installed using the shown adapter (on the G-26) on my well used TRM G-231. The G-26 shown will be used for ratio testing in the Spectra-G after it is broken-in within my X-Cell SE.
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
bigrcr is offline        Reply With Quote
Old 06-17-2005, 02:37 PM   #2
flyinfool
Looks good.
It also looks like it is ready to be put to bed.
I just orderd my 260 3D Max yesterday and need to make up a header to fit it per Bruces instructions.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
flyinfool is offline        Reply With Quote
Old 06-17-2005, 11:55 PM   #3
hyflyr
Damn!!! Is that a tuned pipe or a freakin' baseball bat!!! :mrgreen:
I hope it runs it good.
Scott
hyflyr is offline        Reply With Quote
Old 06-18-2005, 06:35 AM   #4
bigrcr
That's what I said when I first saw it. The neat thing is that the tuned pipe assembly weighs less than the Hatori!!
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 06-18-2005, 07:27 PM   #5
bigrcr
Here are some photos of the installed tuned pipe. Then tuned pipe is lighter than the Hatori by a couple of ounces and after turning the motor around and moving the tank the model balanced perfectly.
So far I have 3 flights (adjustment) on the tuned pipe system and am dialing in the throttle curves. The tuned pipe gives the motor a good deal more power and is a bit louder than the Hatori, but has a pleasant ding, da, ding, ding, da-ding sound :mrgreen: When the pipe "hits" on spool up, it will rabbit ear the main blades until they catch up! Of course, I adjusted the throttle curve to eliminate this! Full power is something to behold.
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 06-19-2005, 02:58 PM   #6
WillJames
I got some vodeo of the climbout and the soud of the pipe, will try to post ASAP.
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 06-21-2005, 04:28 PM   #7
WillJames
Here are a few more pics. I hope to get the bvideo out tonight.
William James
Old 06-21-2005, 04:37 PM   #8
NolanManley
Have ya trimmed a canopy for it yet or does it need trimming?
Reminds me of my Motocross days.
Album
Trex 700E & N, Stratus, Atom, Knight 3D, Vibe 50, & Protos.
RREMODELS.COM, Magnum Fuel, KBDD intl Products
NolanManley is offline        Reply With Quote
Old 06-21-2005, 05:00 PM   #9
bigrcr
I have not trimmed a canopy yet. I have a new Tempest canopy to use. I am currently using a hacked up canopy that I originally used on the prototype when I first got it built. The entire bottom was cut out (so that I could see the model, yet see what was going on) early on in the Spectra-G testing. Not the best looking thing, but it works!
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 06-21-2005, 05:39 PM   #10
Billme
I like the header connection, that should work good!
Bill
Billme is offline        Reply With Quote
Old 06-22-2005, 10:01 AM   #11
WillJames
Video at the link below!!!
http://www.helifreak.com/post-54388.html
William James
Old 06-22-2005, 11:56 AM   #12
DebianDog
Is that a muffler in you pocket or are you just glad to see me? :mrgreen: Sorry... long day.
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 06-22-2005, 12:28 PM   #13
WillJames
HAHAHAH Good one! It is somewhat large so far.
What'd you think of the video????
William James
Old 06-22-2005, 01:36 PM   #14
DebianDog
I was impressed with the PERFORMANCE heck when the bird is on the ground and you crack the thottle open it looks like the gyro has a lot of work to do
That's a bad ass gasser! AND still in beta "test mode"!
Old 06-22-2005, 05:40 PM   #15
Dr_Fibinotchi
wow. I am really impressed. And it looks like some serious thought went into this. What I really like it the connection to the motor part. On some other designs out there its impossible to get the bolts to the motor. As well the support on the tail part looks like a clean and user friendly aproach.
Let me know when this it out...
-Cody
Gas me up and fly
Dr_Fibinotchi is offline        Reply With Quote
Old 06-23-2005, 12:07 AM   #16
Crazy Horse
are you sure you can handle all that HP cody???!
looks like that hummer has some snap!
Crazy Horse is offline        Reply With Quote
Old 06-23-2005, 05:24 AM   #17
RTHanley
nice sounding pipe
RTHanley is offline        Reply With Quote
Old 07-01-2005, 07:32 AM   #18
bigrcr
Good news with this pipe!
-No problem with the mount, it is staying on without any issues.
-The throttle transition is very smooth and predictive. At first the power was available right off of idle and the model spooled too quickly (like an electric) and folded back the blades. I cured that with the throttle curve.
-The sound although louder than the Hatori is not too loud and most think that it really sounds cool.
-The needles are very easy to set using the top down method (too rich first and lean down a bit at a time).
-The motor is running cool showing no signs of overheating.
-The pipe has a very broad range as set. This is great!
-The TRM G-231 and pipe combo makes tremendous power!!
I found that to properly zero in on the needle settings is straight forward. I made the needles purposely rich (as seen in the first video) and then:
-Set the bottom needle after warm up to a fat and consistent idle (on the slight lumpy side from dead smooth).
-Flew the model and made several powered climbs leaning the top needle a bit each time until the motor cleaned up. During this time the full power was still very good while being very rich, but as the throttle cam back off of full the motor would load and almost quit. What was happening was that the pipe was scavenging and stuffing the cylinder with fuel and being so rich would load too much fuel in the cylinder once the throttle was reduced. Once leaned down, the motor acted normally.
-Richened the low needle a very small amount to help feed fuel into the transition point.
-Checked the plug and found it going ever so slightly Grey. I cleaned the plug and re-installed.
-Richened the top needle a small bit and rechecked the plug. The plug is now back to the light tan color.
That was it! Now this model has nearly too much power!!! :glasses: :glasses: Very COOL!
We will be getting some flight video this weekend at BlackSheep to post ASAP so that everyone can see and hear this combo perform.
Stay tuned............................................. ..........
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 07-03-2005, 03:21 PM   #19
Crazy Horse
Oh no problems with us staying tooned John :mrgreen:
Its really great to hear all those positive results! Is there any chance you've bolted one up to the 260 proto to see its reaction?? :glasses:
Also wondering if its fairly certain this gem will be released once the proving ground has been covered.
Old 09-18-2005, 07:41 PM   #20
thenewguy
When is the pipe going to be released?
thenewguy is offline        Reply With Quote
