Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters > TRM Power
TRM Power TRM Power - Toxic Al Factory Support Forum Worldwide. Any Product.
Old 09-21-2005, 08:27 AM   #21
big dee
about time we may get a good combination and can this hatori :glasses:
spectra g 3D/toxic 231/hatori/sab/gy4601/gv1/statorgator/
stratus/os91cspec/cline/k&s/9252/gy601/gv1
Raptor 90 ys80 hatori
Raptor 50 os50 m\p2
kalt baron/0s46sxh/bwhead/9202/9206
kalt baron/os50sxh
Hornet2
big dee is offline        Reply With Quote
Old 01-15-2006, 10:41 PM   #22
bevoduz
is t his pipe ready yet or what?
BevoDuz
bevoduz is offline        Reply With Quote
Old 03-05-2006, 12:50 PM   #23
Dr_Fibinotchi
Default what is status on pipe?
anyone? This seemed to die...
-Cody
Gas me up and fly
Dr_Fibinotchi is offline        Reply With Quote
Old 03-05-2006, 02:55 PM   #24
Toxic Al
to repond about the pipe release date it has been moved, the pipe great power and is light and easy to set up but six months into testing the header had a freak
break and I wanted to redesign it before we had any problems. John had a wreck
with his bird so we are going to torture test the new pipe soon. I will keep you posted cuz I want the pipe out there. Peace, Toxic Al :twisted:
Toxic Al is offline        Reply With Quote
Old 03-05-2006, 06:55 PM   #25
WillJames
John flew both of his birds today,he is back with it Al. John flew very well actually and was wringing them out pretty good!!
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 03-06-2006, 06:15 PM   #26
bigrcr
Thanks Will and Al. Yes the models (Spectra-G and #1005 SE) are both in the air again. I did have an incident a while back with the Spectra-G and had to a partial rebuild.
Apparently I had failed to do a bit of preventative maintenance and had the tail come off of the machine in flight. This was no box/tail gear/shaft failure so all of you can relax, just a bit of oversight that was nearly all the pilots failure to do proper PM. My tail clamp has loosened and I tightened it back (old closed box and mounting) not realizing that the loose box had damaged the boom notch. The neat part was that the model landed on the head and there was no damage within the frames other than bending the clutch center block!! I completed the PM, reassembled and am now back-up and going using the same closed box and mounting as the production Spectra-G now uses.
Testing can now resume! See you all at B'Ham if you are going.
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
bigrcr is offline        Reply With Quote
Old 06-04-2006, 06:30 AM   #27
CustomPC
Any News on the delivery date of these pipes?
CustomPC is offline        Reply With Quote
Old 06-04-2006, 10:46 AM   #28
bigrcr
Not Yet. Al has been crazy busy lately but I should be getting the pipe back soon. Everyones shedules and work loads have been taking a wee bit of a toll.....
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 09-17-2006, 03:28 AM   #29
CustomPC
Any progress on this pipe over the last 3 months?
Old 09-17-2006, 12:29 PM   #30
asong26
Later,
John,
With the TRM tuned pipe being delayed, what would be your second choice for the exhaust? I've sent my G231 to Toxic Al for mods, and I would like to get a pipe that is best suited for the TRM 231.
Thanks.
asong26 is offline        Reply With Quote
Old 09-18-2006, 06:51 PM   #31
bigrcr
I should have the pipe soon for additional testing..........
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 09-18-2006, 07:02 PM   #32
asong26
Man, that's a great news! When I first saw the video of your spectra doing 3D, I was very impressed. Please keep us informed early and often.
thx
Old 11-23-2006, 11:20 PM   #33
asong26
John,
Any word on this? It sure is quiet around here...
Old 11-24-2006, 07:46 AM   #34
bigrcr
No pipe as of yet. Al has been side tracked a bit lately.
Later
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 11-24-2006, 07:11 PM   #35
asong26
How's your engine running? Is it still gaining more power, or would you say that it has peaked out?
I do have a question regarding the maximum power. John I spoke with Toxic Al few months back, Al told me that based on limited testing, he has found the 'Happy' RPM of 12,500. One thing I didn't ask him was with what pipe is that number valid? If you're using Century V2 muffler, would it still be 12,500, or lower?
Also, since you guys had much more time running this engine, and Al's quote was few months old, would you say that this is still the case, or has your engine found a 'Happier' RPM with further tweaking and breaking in.
Lastly, what fuel mixture and needle settings are you using now after about a year of use? Has it changed any?
Thanks John.
Old 11-26-2006, 10:44 AM   #36
bigrcr
My motor is running just fine. The horsepower has peaked and the motor is still very strong.
The happy point is at 12,500-12,750 using a tuned muffler unit. The v2 Centurt and the Hatori both like this RPM and work very well.
Using the TRM tuned pipe, the RPM likes to be 13,000 to 13,250 and the power is amazing since the horsepower is raised at 33% (from @ 2.8 to 3.8 HP).
I have found that either the Hatori or Century will operate just fine at 13,000 RPM as well.
You are correct, this new 13,000 RPM range is with a fully broken in motor. I would only recommend this RPM however, if you know the carb and needles extremely well. This RPM is running the carb on it's borderline of needle/flow settings and result in having to have a very fined tuned needle (both of the needels are open very much H=2 turns and L=1 2/8).
Using the same fuel mixture at 50:1
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 11-26-2006, 03:10 PM   #37
asong26
Later,
John,
Thank you for the update. While this is great news, but confusing to me at the same time. I can see where 2 full turns on the high needle would make sense. But why have you leaned out the low needle? I thought the rule of thumb was not never, ever go below 1 3/8. Or was that just safe setting to make sure that a noob like me wouldn't burn the engine out?
Old 11-26-2006, 10:04 PM   #38
asong26
Default One more question and comment.
Is it safe to assume your low needle setting of 1 2/8 is a typo?
What about velocity stacks? Would you recommend them? I know that debris is a concern, so I am considering one of these...
http://www.davesmotors.com/store/product101.html
Old 11-27-2006, 04:28 PM   #39
bigrcr
Yes, it's a typo. L=1 3/8
Later,
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 11-27-2006, 10:51 PM   #40
asong26
Later,
Thanks John. I've also gone ahead and ordered a velocity stack from DDM. This is the proline version that will be contained within a air filter. If you feel that the velocity stack will affect the needle settings, please do let me know. Otherwise I'll just assume all is well with the v-stack.
Thank you.
