Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Bantam
Bantam Bantam e-Station Charger Support Forum
Old 04-28-2009, 10:56 AM   #161
flatsman9
It is on the Align box, so does that mean it will also charge the Zippy packs?
Trex 500ESP / Spektrum DX7
flatsman9 is offline        Reply With Quote
Old 04-28-2009, 12:38 PM   #162
RC Accessory
Yes
Evan Chapkis
Auth US Bantam Importer & and US Service Center
RC Accessory is offline        Reply With Quote
Old 04-30-2009, 05:05 AM   #163
Greg1971
Does anyone have a solution for e-station for windows on a 64bit operating system. It wont install on my vista laptop. I've tried contacting Bantam but they didn't reply.
Iv'e posted this problem in another forum but still don't have a solution.
Align T-Rex 450SE V2 JR DSX9
Align T-Rex 600 Super Nitro Pro (yellow & Black) Align T-Rex 700N Align T-Rex 600 EFL Pro
Greg1971 is offline        Reply With Quote
Old 04-30-2009, 05:07 AM   #164
RC Accessory
Sorry, the Bantam program does not run on Visat 64-bit OS's.
Evan Chapkis
Old 07-05-2009, 03:53 PM   #165
helitom
Default bantam bc8dx
how big of a power supply do i need to run this?right now every power supply i have tried will kick it off if i try to charge over 5 amps on my 6s 4900packs.then the charger says low voltage input?same thing happens when trying to charge 2 3s 2200 packs over 3amps at the same time but with no message,it will just start over at the beginning screen.thanks for the help.
helitom is offline        Reply With Quote
Old 07-05-2009, 09:01 PM   #166
RC Accessory
I use a 13.8V 30 Amp power supply.
Are you getting a Low voltage error or is the unit resetting?
Evan Chapkis
Old 07-06-2009, 04:08 PM   #167
helitom
Both,i get the low voltage one when doing 6s and it resets while doing 2 3s at the same time.
Old 07-06-2009, 05:01 PM   #168
RC Accessory
What is the voltage and amperage of your power supply? I put a watt meter in between the power supply and charger and charged 2 6S packs (5000 mah) at greater than 1C and was pulling about 19 amps according to the watt meter, voltage was 13.5 Volts.
Evan Chapkis
Old 07-25-2009, 11:36 AM   #169
Patrick74
Exclamation
Hi,
Try with this software http://www.logview.info/
You can choose the language in "English"
(Still have a bug on Windows 7, but hoping it will be resolved asap)
Have fun
Patrick
Patrick74 is offline        Reply With Quote
Old 08-13-2009, 02:47 PM   #170
RcHeliVirgin
Default Using 2 x BC6 on a feild Battery
Hi,
Does anyone know if i can safely use 2 BC6 Dual power chargers off a 75amp deep cycle feild battery to charge my 6s(3300mAh) & 3s packs (850mAh).
Example:
Use both chargers to charge a 6s each, this way i can get both packs done in 1.5 hours meaning more flying time .
Cheers..
RcHeliVirgin is offline        Reply With Quote
Old 12-06-2009, 03:51 PM   #171
oldgrandpa
What do I need to charge two Zippy 3s 2200 hooked in series as a 6s 2200 using a BC6 charger,( Charging both at same time)
oldgrandpa
oldgrandpa is offline        Reply With Quote
Old 12-06-2009, 04:42 PM   #172
RC Accessory
oldgrandpa
You need this http://www.rcaccessory.com/bantame-s...6twometer.aspx and the series connector on the pull down menu.
Evan Chapkis
Old 12-06-2009, 05:01 PM   #173
oldgrandpa
Thanks for your quick reply
oldgrandpa
Old 12-15-2009, 07:46 AM   #174
Goldstripe
Default Charging 2 3s Zippy 5000's
Hi Evan,
If you've answered this question before I apologize for the redundancy ahead of time. I have the dual balance board so I charge in series as a single 6s 5000 battery. No issues detecting all the cells and charging/balancing them. The issue I see is that despite the fact that I have the amperage set for 5 amps, the actual current applied never gets close to that. Usually it's around 2.5a yet if I charge 1 at a time the amperage starts off at 5a and obviously goes down from there like normal.
Any idea why it would do that?
Goldstripe is offline        Reply With Quote
Old 12-15-2009, 10:49 AM   #175
TJinGuy
Read the center column for the likely answer.
http://sites.google.com/site/tjinguy...doing-the-math
- Chris
heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote
Old 12-15-2009, 12:49 PM   #176
Goldstripe
Thank you TJinGuy! So if I follow the math then for (2) 3s in series I need:
25.2v * 5amp = 126 watts. Manual says max of 50 so basically the only thing it could charge at 5amps is a 5000mah 7.4v (2s) pack or less. That's awful and very misleading considering the manual doesn't state that up front, you have to go to the very last page for that info.
I wonder if that charging max output can be changed in some way?
Old 12-15-2009, 02:27 PM   #177
TJinGuy
Yep people need to be informed about these things before they buy a charger and that is why I made the site.
Want to hear even worse? Check out the TP610c. It proudly states that it is rated for 6s and up to 10A but in reality it has a max wattage of 80W. That means you can't even charge a 2s pack at 10A !?!?!
- Chris
Old 12-15-2009, 02:54 PM   #178
Goldstripe
Wow, that is bad! I've had the charger over a year so I'm sure it's out of warranty. I may talk to someone (electrical engineer buddy) about how to modify that wattage limitation. Probably not possible but it's worth a phone call.
Otherwise I'll be selling it off I guess. I'm sick of waiting 3 hours for my 2 3s 5000s to charge.
Old 12-15-2009, 03:04 PM   #179
TJinGuy
That is why there is so much talk on the forums about higher power chargers. There are some that can output 350W! That will charge a 6s pack at nearly 14A! Maybe it is time to upgrade?
- Chris
Old 12-15-2009, 03:41 PM   #180
Goldstripe
Sounds like it is time to upgrade. And I'm not even a heli guy. Well, I sorta am (little blade cx2) but I ran into this problem charging packs for my brushless revo. It's gotta be 3 times worse for heli guys!!
