| Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters |
I did a search but I couldn't find a thread for people showing off their Leptons so how about this one? Post your pics here so we can compare setups & canopies! Here are a few of mine.
EDIT: THX Fireup for the sticky!!!
Currently Flying! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123 Retired Helis - Blade CX, Blade CPP, TRex450SE, To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by cybinary; 03-24-2008 at 10:12 PM.. Reason: giving thx |
Here's mine
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (~¿ö)
Here's another one.
Hyperion H-3025 10 turn. Jeti SPIN 66 Amp ESC. Airtronics 94761Z Digital Servo. Futaba GY 401 / Futaba 9650. Max Amps 4s 4000 MAH. (great batteries) |
here you go.
DX18 ; Logo 500, Gaui X4 II |
hi i'm new with my hdx 500 i woul like to know if by chance you know what is the pitch curve
#6 |
This doesn't have anything to do with pictures of Leptons. You'd get a lot better results making a thread, and waiting for someone that can help to come along and answer. Posting the same question in unrelated threads isn't going to yield good results.
#7 |
Another - I did want to wait till Vblades arrived but had the camera out
#8 |
After a ridiculously bad crash, here's the Lepton with HDX 13t tail pinion, boom support rods and boom mount used for the support rod mount wich I think looks cool but used to reduce slipping on the boom thus less vib's - overall, heaps better tail control.
#9 |
Here is mine, Put new T500 landing gear after these pic.
Wooohoo.... |
#10 |
Here's mine again with a makeover.
#11 |
Nice, Is that the Align airwolf fuse? Did you have any problems getting it to fit?
Currently Flying! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123 Retired Helis - Blade CX, Blade CPP, TRex450SE, To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#12 |
Wow, Thats really clean. I'm not into scale but that one of the better jobs ive seen. Should do a pic witht the retract down too. Looks great!
Wooohoo.... |
#13 |
here's mine. sorry for the quality as i only had a camera phone when i took it
#14 |
Here's my Lepton with the following:
3102's on cyclic, Spartan DS760 with 9254(helped tremendously with controlling the tail), Jazz 80-6-18, Castle Creations BEC, Hyperion 3025-12 w/ 24t, MJP Carbon lift kit, ESC mount and fin set, Hirobo Stretched boom w/belt (paired with the spartan gives me a bullet-proof solid tail), Trex500 Boom supports, custom CF tail pushrod, MAH 425 main blades and Gorilla Gear lightweight paddles (these alone speed up the cyclics substantially) along with the blade grip ball links mounted in the inner holes and the outer holes on the bellcranks including using the upper hole on the main shaft(which brings the whole rotor head closer to the frame) makes this machine very nimble and quick without the need to run a ridiculous head speed or power system. All this powered by Outrage 4S Lipos. ![]() ![]() ![]() ![]() |
#15 |
wondering if possible to get a torque tube??
also i hear they have a kit to stretch out the leptop, how much bigger? |
#16 |
Is that a die job with that yellow lid? sure looks nice/different.
I got crazy cyclic with the same servos and modest head speed governed 2700-2800 Scorpion 980Kv and lighter TP 4's 2200's than the 3850's that I still use once in a while. Flight time is down to about 3:30 mins though. My tail is solid with new T63 gear, 401 and rave tail blades, Acts like the seconds hand on a watch when I'm working it. No bounce no wag just solid. I have to updates my album one of these days.
Wooohoo.... Last edited by corona007; 08-01-2009 at 10:01 PM.. Reason: correction |
#17 |
its flourescent yellow outta the can! Bunch of clearcoat on top of that! yea these servos are wicked fast using the inner holes on the main blades grips.
#18 |
Futaba 10c
Scorpion 3026 880KV Castle ice 50 ESC Castle 10 BEC SJGD PG800 Gyro Futaba s9257 tail servo Hitec HS5085 MG 3700mah 4s 20c Radix 430 Main Blade CF 62mm tail blade Main Gear 94 Pinion 24 Tail Gear 13t |
#19 | |
Sweeeeet....
Wooohoo.... |
#20 |
I love the Lepton.
Lepton Ex TREX 700E |
